2002 hilux sr5 headlight conversion
stufftheIFS-
Unread post by stufftheIFS- » December 28th, 2011, 6:08 pm
here we are boxing day 2011 4 years after i started my hilux build and now i'm doing all the finishing touches
2002 RZN149R to ln150 sr5 Headlight conversion, this is a relitively simple conversion for those with some mecanical aptitude (i'd never done this before so it was totaly guess work for me and thought i'd make it easier for others and blog it step by step )
step one
remove all standard grill by sliding the plastic clips down, unscrew the indicators and remove , un screw lights and remove
step two
now once you have everthing removed you wil see the light buckets (brackets the lights are bolted two ) they look like the picture below
step three
now drill out the 6 spot welds you will see them as round indents like you driled a 1mm deep hole
once you have done this you are ready to apply some force in the form of a cold chisel and hammer
light bucket removed
then you will have a bare radiator support panel like this pictured below
step four
now you are ready to mount the new rn150 light mounts you will find these attached to your lights . there is no need for drilling all holes are already there including guild holes .
brackets mounted
step five
once the brackets are in you can fit your new ln150 lights i used the performance brand from panelhouse in slacks creek $260 complete with every thing needed to fit .
comparison of the two lights
jPathy
Re: 2002 hilux sr5 headlight conversion
Unread post by jPathy » December 29th, 2011, 3:33 pm
They are nice lights. I put them in mine a few months ago but they ate too high on the passenger side and blind people badly. I have had to do a fair bit of work to redesign the cut off plate to make them suitable to drive with so I'm not blinding everyone.
Synergy
Unread post by Synergy » January 21st, 2012, 10:32 am
how did you centre the light so they face straight? I did the same conversion and they cross each other on high beam lol
luxy 99
Unread post by luxy 99 » January 21st, 2012, 3:17 pm
looks good would it be the same steps for the
1999 luxes
stufftheIFS-
Unread post by stufftheIFS- » January 22nd, 2012, 1:31 pm
g'day bud , no mate you need to change the radiator support and bonnet on the 97-99
Dazza14
Unread post by Dazza14 » May 11th, 2012, 3:24 pm
i have a 2004 hilux 3.0D and wanting to do this is there anyone on the Gold Coast would be willing to help me do this cash in hand job i have everything, i hate the square sealed beams just ugly.
thanks Dale
NZ LUX
Unread post by NZ LUX » May 11th, 2012, 5:18 pm
Looks like I got away with modifying anything on my 2000 RZN169R Hilux
Kajiado
Unread post by Kajiado » July 25th, 2018, 5:07 am
Any idea how difficult this would be on a 95 ln106?
Return to “HiLux”
