Got or want bigger tyres? Come in here... ;)
hiluxmatt2
Re: 2006 Hilux Tyres What will fit?
Unread post by hiluxmatt2 » February 7th, 2014, 11:18 am
hi there, I have a 2006 hilux and im running 33's with 2 inch suspension lift and -5 mag offset no rubbing but to keep the power there changed diff gear ratios from 3.58:1 to 3.9:1
Matthew Ingram
taresk
Re: Fitting different wheels and tyres to 2014 Hilux Dual Ca
Unread post by taresk » May 24th, 2014, 8:37 pm
Jute
From what I've read, there are a handful of 16's that will clear the calipers, but most won't, this is why there's confusion about it. I don't know which ones do fit (never needed to look into it), but might help if you can find some to trial fit from different wheel manufacturers.
dropzone
Unread post by dropzone » July 18th, 2014, 9:12 pm
1981. 4" lift with High steer 35x12.50's
ihafln
Hilux 2012 sr 4x4 turbo diesel tyre size???
Unread post by ihafln » July 21st, 2014, 5:10 pm
Hello Im rather new to the 4x4 scene and i got my hilux not too long ago but dont really like the standard tyres on it being so thing and small.. my brother in law got some 4x4 tyres and tried to put them on it as i wasn't sure if they would fit but would scratch when turning.. ive spent awhile searching for some help on size's but cant find it.. if anyone knows what type of tyre size's i can fit on it any help would be much appreciated thanks
cowan kid
2013 Hilux 2" lift - What offset rim works best for 33's?
Unread post by cowan kid » July 23rd, 2014, 4:16 pm
G'day all
was just looking for some advice, im planning on lifting my hilux with 2 inch suspension and fitting 33's.. my question is when it comes to rims what offset works best? also if anyone has come across problems with this lift??
Michael
Rogers Cruiser
Re: 2013 Hilux 2" lift - What offset rim works best for 33's
Unread post by Rogers Cruiser » July 23rd, 2014, 4:36 pm
2" lift at 33's is going to be a stretch! no wait cancel that, they will just not fit!
32's will still scrub unless you are at an extreme offset.
31's and a hilux sound pretty good.
Goodluck
cowan kid
Unread post by cowan kid » July 31st, 2014, 5:35 pm
cheers mate, iv organised for a tad of a body trim to fit the 33's but curious as to what offset id be looking at?
cowan kid
Rim offset to fit lifted hilux????
Unread post by cowan kid » July 31st, 2014, 7:31 pm
Hi all
I'm in the process of lifting my 2013 sr5 lux with a 2" suspension lift and I'm planning to fit 33's to suit! Now I'm planning on trimming and re-plating the wheel arches to fit without scrub but I'm completely stuffed when it comes to working out what offset is best! In fact what's the bloody difference? Lol
Any information will be greatly appreciated!
Cheers, Michael
cowan kid
Hi all
Cheers, Michael
Harry Clark
fitting 33's to my 97 saf
Unread post by Harry Clark » August 17th, 2014, 8:09 pm
hi guys im looking at fitting some 33's to my saf hilux and was looking at bolt on kits instead of a diff push, and so my question is would i able to fit 33's with only 3 inch spring lift and maybe a rim offset or would i need to go up to a 4inch the reason im asking is that most of the 4 inch kits have extended shackles which are illegal in my state.
cheers Harry
KidLux 09
best wheel size for 2" lifted 09 hilux
Unread post by KidLux 09 » November 12th, 2014, 6:21 pm
Hey,
Whats the best wheel and tyre size for a 2009 sr hilux with 2" suspension lift. Also has anyone blocked the egr on there lux. If so, please share proccess.
KidLux 09
Re: best wheel size for 2" lifted 09 hilux
Unread post by KidLux 09 » November 12th, 2014, 6:24 pm
Also, are Mickey Thompson Deegan 38's any good on the bitumen.
02-SR5
Unread post by 02-SR5 » November 12th, 2014, 7:07 pm
265/75/16 on a 16x8 inch rim with a zero offset.
You can fit 33s with a bit of "engineering", but the 265's (32's) are a great compromise between lift and fit with no modifications to the body.
KidLux 09
Unread post by KidLux 09 » November 13th, 2014, 4:05 pm
Thanks. I wasnt sure if you could go 33s without any contact or rubbing.
Cheers.
bushwacka_macka
Hilux tyre swap
Unread post by bushwacka_macka » February 8th, 2015, 12:27 pm
Hi all. Will the steel 17" rims from 2014 hilux SR fit a 2013 hilux SR5. Which run 17" alloys as standard.
Return to “HiLux”
