Got or want bigger tyres? Come in here... ;)
Nemesis
Unread post by Nemesis » June 4th, 2011, 12:29 pm
Okay guys, we need your collective experience for some research on the unbreakables.
What we need to know is whether you have 33" tyres, or managed to squeeze 35" tyres under your Hilux, particularly newer models but all wanted.
If so, how much lift required to do the job? Spring lift? Body lift? Guard chops?
Unfortunately, knowing your brothers mates cousins second best mate apparently did x" for x tyres won't cut it. We need facts if possible, what lift fits what tyres, guaranteed.
Your proven advice will go a long way to helping a lot of people!
Nem ;)
Synergy
Unread post by Synergy » June 4th, 2011, 12:41 pm
33" with a 2" body and a 2" suspension
35" with a 2" body lift and a sagged rear suspension lift. rubs on full lock only offroad.
35's with a 2" and 2" lifts = rubbage offroad
85_LUX
Unread post by 85_LUX » June 4th, 2011, 1:32 pm
SAF hilux' to fit 33's: move the front diff forward 35mm by redrilling driver side spring perch 35mm back (passenger side already has the hole drilled from standard).
sorry having problems getting photo's to work. i'll try get some up later
foot to the floor in the 2.4
Check out my hilux build up
viewtopic.php?f=22&t=105716
Defiance
Unread post by Defiance » June 4th, 2011, 6:13 pm
31" Will fit under a 97 Hilux with only slight raising of Torsion bar. No Scrub.
emmo143
Unread post by emmo143 » June 4th, 2011, 11:18 pm
33's with 4inch suspension: rubbage offroad (suspension is pretty damn soft so that wouldnt help)
Aaron Schubert
Unread post by Aaron Schubert » June 4th, 2011, 11:24 pm
Ive got 33x12.5 on my solid axle hilux, with just a 2 inch body lift and some very sagged suspension. I would guess it sits about the same height as a standard hilux. The tyres rub just on full lock and a bit more when flexing, but nothing to be concerned about
Aaron
My 80 Series Landcruiser
dudelux
Unread post by dudelux » June 5th, 2011, 1:05 pm
Ive got an 86 Lux, with only a 2inch body lift, running 35s daily, and 33inch Swampers for play.
The tyres rub on the rear of the front guards under any flex, so when I do RUF, and move the front diff forward, it should be sweet.
The Swampers do more damage to the guards than the 35s, but you get that.
4x4lux
Unread post by 4x4lux » June 5th, 2011, 3:01 pm
i run 33 x 12.5 on my 2001 hilux, tyres rub on idler arms on full lock .... from what ive measured i have close to a zero offset , ive been told by king wheels seven hills sydney i need a neg 23 offset to fit the width eg 12.5 if i were to drop to a 10.5 wide theyd fit on current rims ,hope this helps
96 ln106 SAF bullbar side protection sliders safari snorkel light force 240 spotties rock lights goodyear MT wrangler 33s on black sunnies 7 inch lift awning plenty of extras LUX-URIOUS !! ;)
Synergy
Unread post by Synergy » June 5th, 2011, 3:38 pm
Should ask on newhilux.net for the newer luxs nem.
Alesnik
Unread post by Alesnik » June 5th, 2011, 6:17 pm
2002 IFS Lux 2" lift 32x11.5 on 15s with cruiser off set, bit of rubbage on uptravel and lock
With 1" body lift added, no more rubbing
Cartman
Unread post by Cartman » June 6th, 2011, 12:36 pm
got SAF, 2" suspension 2" shackles and only rubs on when flexing on lock, straight up and down has no problems.
Hits on the back of the front guard.
4x4lux
Unread post by 4x4lux » June 6th, 2011, 4:43 pm
alesnik ---cruiser offset neg 23 yeah ??
johno88
Unread post by johno88 » June 6th, 2011, 5:37 pm
solid front axle, 2in body and 2in spring with diff moved 35mm forward has no srubbling with 33x12, put 1inch bump stop extension and fit simex 35x10.5 with negative 44 off set rims with bugger all scrubbing
johno88
Unread post by johno88 » June 6th, 2011, 5:42 pm
with 33s
tuffskid
Unread post by tuffskid » June 6th, 2011, 7:54 pm
34's... 3inch front springs 2 inch ifs rears... front diff moved forward 35mm... no scrubbing anywhere!!!!!!
Return to “HiLux”
