landcruiser 200 series tyres
Arsenal Cruiser
Re: landcruiser 200 series tyres
Unread post by Arsenal Cruiser » July 25th, 2011, 6:02 pm
Where abouts are you Tonkatoyota?
Tonkatoyota
Unread post by Tonkatoyota » July 25th, 2011, 7:40 pm
Sydney.
LandCruiser 200 VX 4.5 V8 TTD - Cooper STTs, Safari Snorkel, OME Nitrocharger Sport shocks & 2" lift.
Arsenal Cruiser
Unread post by Arsenal Cruiser » July 25th, 2011, 9:53 pm
Had a feeling that you weren't local. My recommendation won't be any good to you then. LOL. Sorry mate.
sahara09
Unread post by sahara09 » August 1st, 2011, 1:57 pm
have gone to the 694,s LT Bridgestone 285/65/R17 so far they seem very good quiet and actually grip better than the dunlops did only thing they are speed rated to constant 190kph instead od 210kph so ill just have to drive slower :crazy:
ANGRY HORNET
Unread post by ANGRY HORNET » August 2nd, 2011, 12:37 am
I have recently fitted 285/70 17 COOPER STT's to my 200 series
Am very happy with the tyres as I have been running coopers for the last 6 or so years now
The only problem I have is that the fuel economy has turned to crap
I have lost approx 200-250 km per tank
Has anyone had or heard of this happening to others that have done similar...???
I have also fitted the Roo System chip and Exhaust system ..... Thinking that this would of counter acted the tyre upgrade but it seems not
:confused:
Adrian
ANGRY HORNET435
Red1
Unread post by Red1 » August 2nd, 2011, 5:56 pm
Put on a set of Mickey Thompson ATZ 5 rib 285 70R17's
Have done about 4000km and they seem to be OK. No noise and they ride really well.
4xgold
Unread post by 4xgold » August 31st, 2011, 9:39 pm
Got a set of Mickey Thompson 305 65 R17 ATZ4 for the GXL.
They just miss the plastic guard by 10mm on the front on 3/4 lock
I have 50mm lift but more lift wouldn't make any difference as it is
against the horizontal body that it is close. They are only 3% larger
in diameter than the factory tyres.
lockie86
which tyres do you have
Unread post by lockie86 » November 27th, 2012, 6:22 pm
im thinking of getting either cooper STT or mickey thompsons MTZ.
wound like to know your thoughts on these tyres or others
thanks
custard0_12
Unread post by custard0_12 » November 4th, 2013, 8:51 am
Gidday,
I am just about to put new tyres on my 200 series, first ones since new! I bought the car new in March 2009, and put BF Goodrich All Terains 285/70 R17 on it before I picked it up from Toyota. I have travelled 107,000 klms thus far on them, and not quite down the the wear mark indicators. I regularly have them serviced every 10K at Bob Jane, and there has been plenty of off road stuff as well, last trip was to Broom in WA via Gib River Road. Plenty of caravan towing as well. I believe that most tyres should give you a reasonable life as long as you look after them, balance and rotation is the key.
Hope this helps.
P.S. The next set will obviously be another round of BF Goodrich
Raydingo
Unread post by Raydingo » February 22nd, 2014, 7:11 pm
I have the STD tire from new on my LC200, have got 60 kl out of them but the shoulders have gone off. Am looking for a longer lasting tire what should I look at? I do most town and highway and not much dirt
Unread post by mydmax » February 22nd, 2014, 7:33 pm
Raydingo
What pressure did you run in those tyres?
If the shoulders are worn off all the tyres, it would indicate insufficient inflation pressure and that will reduce the life by causing more surface pressure to be applied through the shoulder than the whole tread at once, and it would also be making them run hotter which will shorten life.
matske
Unread post by matske » November 16th, 2014, 12:07 pm
Has anyone tried nitto tyres 285 60 18 on there cruiser or mickey thompson atz in 275 70 18
Return to “200 Series”
