Show us ya 100 series
Cruising Brit
Re: Show us ya 100 series
Unread post by Cruising Brit » August 25th, 2014, 12:18 pm
a friend of mine wanted to do exactly the same thing as you in QLD and he was told by various people he couldn't get it engineered. so he did the HD-FTE conversion on his FZJ105 (n/a petrol to turbo diesel)
4WDing, it's not a Hobby, it's a Passion!!!
FZJ105; 2 inch lift, ST/maxx's, HID/led lights, draws, roof rack, sat nav/entertainment system, 2.5 inch Beaudesert exhaust with pacemaker extractors, green P plates, 3 year old behind the wheel :p
viewtopic.php?f=187&t=146189
cambyrom
Unread post by cambyrom » August 26th, 2014, 10:21 pm
I'm no expert but I'd imagine an engine swap would be a whole lot simpler and cheaper than a solid axle conversion. Besides the electrics, a HD-FTE is a straight forward swap in a HZJ105. Most of the cost of the conversion comes from the price of the motor itself, they fetch a good dollar because they're so desirable!
To do a solid axle conversion on a 100, due to the wider chassis vs a 105, you'd have two options, 1. Wide diffs from a different vehicle, or 2. modify the chassis.
If you went option 1 you'd need to get diffs from a completely different vehicle, I don't know what solid axle fourbies had wide enough diffs to get around that IFS chassis, certainly won't get anything from another landcruiser. I'm sure someone on a forum somewhere has looked this up at some point. You'd then need to do a whole heap of bodywork to cover up the wheels give how much wider they'd be, plus I don't know how much of an engineering nightmare it would be to do a 100mm+ wheel track increase.
Option 2 is completely unknown to me. I don't know what the rules are on chassis modifications, what else is central of the chassis that would need to be modified etc. but basically there'd be a lot of cutting, bending and modifying that needs to be done to fit standard 105 diffs under.
Also don't forget that the starting price of a good condition HDJ100 is higher than that of a good condition HZJ105. You could buy a really nice low kms early 2000's HZJ105 for $25k, spend $20k on the conversion, new exhaust and a few other goodies. Or you could spend $35k on an equivalent condition HDJ100. Good luck getting either option 1 or 2 done for under $10k, just won't happen.
Nov '11 to Mar '13 - 1993 HZJ80 Standard
Apr '13 to Oct '13 - 2008 VDJ78 GXL
Oct '13 to Now - 2002 HZJ105 GXL, turbo'd, intercooled, bit of kit, more to come. Build thread: viewtopic.php?f=187&t=152748
paddoNQ
Unread post by paddoNQ » September 23rd, 2014, 9:16 pm
Hey Fellas,
My 105 Standard 4.2 Diesel
No crazy mods yet, simple stuff as follows
>EFS Suspension /lift
>Red Arc Dual Battery system
>ARB Winch bar
>IPF Spotties
>Black Widow Drawers (In the Shed waiting for the wing kit haha)
>Airtec Snorkel
>Premier Winch
285 BFG KM2's
Rhino Racks
Few Plans such as Turbo and Boat Loader Rack, Rear Carrier...
12H-T cruiser
Unread post by 12H-T cruiser » October 15th, 2014, 7:09 pm
Hi all
Thought I'd show off my new to me 100 series, it's 2002 model HDJ100R, stock standard, it even still has the dual batteries connected, here's a couple of pics.
And the all important black box
Can't wait to start the mods
Ivan
1989 HJ61 12H-T
2008 200 Series VX UZJ200 V8
jackson.baker
Unread post by jackson.baker » December 1st, 2014, 6:08 am
Hey Paddo I sent you a PM mate.
Wheeliespin
Unread post by Wheeliespin » February 6th, 2015, 3:30 pm
Hi all this is my 2003 sahara 4.7 LT black Toyota 100 series, winch 9000lb, 2" lift, outback storage, wind cheetah roof rack, on board air arb, cb gme,
OWAF
Matty91
Unread post by Matty91 » February 19th, 2015, 8:04 am
Hey guys! Here's my 105 4.2 with garret turbo, 3inch amanda res shocks, flexy coils, and a few other bits! More to come!
1640hunter
Unread post by 1640hunter » March 10th, 2015, 7:39 pm
So I'm a new 100 series owner - picked up my 2002 HZJ105 GXL Advantage on tuesday and drove it 900km back from brisbane without dramas.
Did a full service on it just now - all fluids, filters and tightened wheel bearings. Will clean and repack all WBs and CVs next weekend. It's nice and stock (best starting point imo), but did come with a GME UHF and a set of new Toyo MTs!
burgerman
Unread post by burgerman » June 19th, 2015, 9:19 pm
2002 100 Series Sahara
4.7 Litre SuperCharged V8
Modified Auto
3 inch Exhaust
ARB Deluxe bar
IPF lights
OME 2 inch lift
Diff drop
Black Widdow drawers
Dual Battery system
Air Bags
210kws on all 4 wheels
Built for towing
DamoBro91
Unread post by DamoBro91 » September 3rd, 2015, 6:10 pm
Some real nice cruisers in here fellas and ladies. Heres one of mine. Still got a fair bit to do yet but its a work in progress.
Return to “100 Series”
