Intermittent squealing noise fm under bonnet - any ideas?
thomo49
Unread post by thomo49 » November 2nd, 2017, 4:30 pm
Hi everyone travelling around aus towing van everything good but every now and then when cold only there is a bit of squealing noise under bonnet take foot off for bit and it disapears i just want an idea what it is for next time we put it in for service they can fix it as i say its not there all the time just now and then or when it's cold cheers thomo49
Re: Intermittent squealing noise fm under bonnet - any ideas
Unread post by Peter Aawen » November 2nd, 2017, 5:39 pm
Any chance it's fan, A/c drive, or pwr steering belt related? Does it only ever happen when one of those loads up?! ie, turning hard, a/c just starting cutting in, or when the viscous hub fan starts driving?? I wouldn't wait for a service, my bet would be that it's most likely one of those belts - check the tension & condition on them all & tighten or replace as applicable, & chances are the noise will be gone! ;)
thomo49
Unread post by thomo49 » November 2nd, 2017, 5:49 pm
Thanks peter will check belts ect
Unread post by Peter Aawen » November 2nd, 2017, 7:50 pm
Just a hint - loosen off any locking nuts before trying to adjust the tension screws/arms on the belts; trying to tighten the belts doesn't work anywhere near as well if you leave the locking nuts tight & you might even break the tension bolt if you try to turn it too hard without undoing the locking nuts. :o :petrified: Please don't ask me how I know this, just take it as read! :urgh: :p
buffer
Unread post by buffer » November 2nd, 2017, 9:17 pm
I have a 100 series and had the same problem definitely the belts and only when cold.
Agree with Peter and please follow instruction on how to tension up the belts, very important.
Return to “100 Series”
