landcruiser 105 ,aftermarket turbo return at sump
jnr78
Unread post by jnr78 » July 8th, 2015, 5:35 pm
Hi all
For those that have fitted an aftermarket turbo kit to their 1HZ What did you use for the return line at the sump and where did you get the part ?
I am after the "bung , hard line ,tube ,pipe " That is welded into the sump.
My return pipe at the turbo is 19mm.
Jnr
vk3aif
Re: landcruiser 105 ,aftermarket turbo return at sump
Unread post by vk3aif » July 9th, 2015, 9:50 pm
On one of my sons 1HZ we just bronzed a hosetail into the sump. The sump came off with engine in car easy enough and was double skined from memory. I believe some of the workshops who fit them punch a hole into the sump and use epoxy glue to hold/seal them in there.
Troopen
Unread post by Troopen » January 18th, 2016, 8:05 pm
Did you get this sorted?
Return to “100 Series”
