105 series rim offset
kiwijase
Unread post by kiwijase » August 8th, 2014, 11:13 pm
Hi
I'm currently renewing the wheels and tyres on my 105 series. The tyres I'm fitting will be 285/75 x 16 BFG's, with Sunraysia style rims. My question is what is best rim offset to make use of all the space under the guards.I've been told anywhere from -25 to -30.Any suggestions and photos appreciated.
stretch4x4
Re: 105 series rim offset
Unread post by stretch4x4 » August 9th, 2014, 9:30 am
-25 to -30 will push your wheels out of the guards.. It will make your car wider and more stable but also put more stress on the wheel bearings and steering components..
A 285/75/16 "should" fit in the guards perfectly well on 0 offset rims. Pretty sure there are plenty of people running 105 *" alloy or steel rims on 285s without issues. If you go for the negative offset and push the tyres out depending how far you go you might start having issues on the outside of the guard at full flex.
More info on landcruiser offsets in this thread:
viewtopic.php?f=7&t=153594
Image HDJ79R & Traxxas Summit
kiwijase
Unread post by kiwijase » August 9th, 2014, 9:01 pm
Thank you stretch 4x4,I'll have to do a bit more homework I think.
cambyrom
Unread post by cambyrom » August 9th, 2014, 11:10 pm
I spoke to a guy running 305/70R16 BFG KM2's on 0 offset ROH Blak Trak wheels, 2" lift, no scrub or anything.
I currently run 285's on factory 0 offset steelies, 2" lift, no scrub. I'll upgrade soon to 305's on -13 offset Dynamic steelies, gives a bit wider stance for stability, little to no extra strain on the diffs at that offset, and will sit just inside the guards. Perfect combo in my opinion :D
Nov '11 to Mar '13 - 1993 HZJ80 Standard
Apr '13 to Oct '13 - 2008 VDJ78 GXL
Oct '13 to Now - 2002 HZJ105 GXL, turbo'd, intercooled, bit of kit, more to come. Build thread: viewtopic.php?f=187&t=152748
kiwijase
Unread post by kiwijase » August 10th, 2014, 7:51 pm
Thanks for your input Cambyrom, certainly worth consideration.
Roadwarrior
Unread post by Roadwarrior » August 22nd, 2014, 1:06 am
Kiwijase, Do't know where u are but worth keeping in mind if your in Qld 285/85's are a no go.
kiwijase
Unread post by kiwijase » October 18th, 2014, 12:29 pm
Thank you guys for your help, went with the 285/75 x 16 with Dynamic rims with 0 offset.
Return to “100 Series”
