What does this sensor do?
lucas2911
Unread post by lucas2911 » January 2nd, 2014, 6:00 pm
I have a fzj105 & in between the second battery holder & headlight is a 3 wire sensor? Its bolted to the inner guard in the engine bay with an L arrow & R arrow which has a small hole looks like an adjustment with a small screwdriver?. Is this an adjustment for fine tune of fuel mixture or timing? :crazy:
Bevan'n'Katie
Re: What does this sensor do?
Unread post by Bevan'n'Katie » January 14th, 2014, 12:29 am
i very much doubt it, toyota wouldnt make anything that simple. have you had the car from new ? if not it could be something someone has added as a after market thingy. trace the wires and see where they go if you can. put a photo up as well if you can.
100SEZ
Unread post by 100SEZ » December 18th, 2017, 2:46 pm
fine tune of fuel
don't touch it :)
Return to “100 Series”
