View topic - Holden rodeo's!!!
Holden rodeo's!!!
• Page 1 of 1
Holden rodeo's!!!
i have had so much trouble with my rodeo mainly with the front independant suspension setup but the whole ute has been terrible, every thing going wrong with it and spending heaps of time fixing it for the performance of it to be garbage.
.....a blind whinge huh?
care to lay down some more details...?
what's going wrong with it?
what are you asking it to do?
how often do you drive it?
how many k's?
what condition was it when you bought it?
how do you drive?
did you do the repairs and mods yourself?
how many k's?
how do you drive?
'98 [b]JACKAROO[/b]- GTradial Adventuro Muddies, bullbar, DIY timber centre console, DIY stainless steel snorkel, DIY 100L esky, DIY Campervan fit-out, 2.25" cat back exhaust
[url=http://www.4wdaction.com.au/shed/index.php?content=all&chunk=arbu&user=6858]http://www.4wdaction.com.au/shed/index.php?content=all&chunk=arbu&user=6858[/url][url=http://www.4wdaction.com.au/forum/viewtopic.php?t=60687]http://www.4wdaction.com.au/forum/viewtopic.php?t=60687[/url]
chikoroll wrote:.....a blind whinge huh?
how many k's?
how do you drive?
The main problems are the drive shaft keeps playing up aswell as the hubs won't activate at times and the radiator is clogged up and nothing will free it up i've been looking around for a new 1 but none of them have the connections on the right side and the clutch keeps going on me i've redone it a few times. its done 183,000 kilometers and its had regular services all by me and every thing has been looked at but there are just things going wrong with it all the time. its normally just driven occaisionally on weekends and it doesn't have to much asked of it but i haven't been able to drive it too often because of all the time it spends in the workshop.And top stuff on your jackeroo it looks the good for a great camper.
Sounds you you've got water and mud soup problems getting into everything eg: clutch, radiator fins, 4wd actuators on the front axle etc. It's a common problem on them but they can be sealed up.TOUGH_75! wrote:The main problems are the drive shaft keeps playing up aswell as the hubs won't activate at times and the radiator is clogged up and nothing will free it up i've been looking around for a new 1 but none of them have the connections on the right side and the clutch keeps going on me i've redone it a few times. its done 183,000 kilometers and its had regular services all by me and every thing has been looked at but there are just things going wrong with it all the time. its normally just driven occaisionally on weekends and it doesn't have to much asked of it but i haven't been able to drive it too often because of all the time it spends in the workshop..
When you've replaced the clutch have you had the flywheel machined as well?
Don't loose heart tough 75, they are a top rig, and perhaps some attention to detail will restore it back to the great truck she is.
Remember, fix it right = fix it once. A blocked radiator core, if it wont clean with a few bottles of flush, just give it a re-core, and keep the original tanks, and it will be better than one from the wreckers, and last longer, and save you from the risk of blowing your head.
When doing clutches on 4x4, be carefull not to rest the weight of the box on the pressure plate fingers, because they can bend, and reduce the life of the clutch, and as mentioned always machine the flywheel and replace the spiggot bush. I got 150,000km on my last clutch (r9 4jb1t).
Your free wheelin' hubs are easily serviced, cleaned and repaired if needed.
Good luck, michael.
Good luck, michael.
sudso wrote:Sounds you you've got water and mud soup problems getting into everything eg: clutch, radiator fins, 4wd actuators on the front axle etc. It's a common problem on them but they can be sealed up.
Sudso when you say things that need to be sealed should i be looking into this before venturing into any water on the rig?
Jasonr23 wrote:Sudso when you say things that need to be sealed should i be looking into this before venturing into any water on the rig?
Yep!
Speaking from experience here from when I owned a Rodeo. A TFS R9 V6 model but still the same critter basically. Mates R9 2.8TD had a flooded starter motor too.
Things to do for preventing water entry are common on most 4by's though but Rodeo's have a few points which need particular attention.
4wd Actuator on front axle & Transfer case (only for non manual hubs)
Starter motor
Clutch fork boot
Bell housing to engine
Diff and g/box breathers up high enough?
What's wrong with front suspension?
• Page 1 of 1
Who is online
Users browsing this forum: acheshifter, andrewm, anybot, Aussie_Dan
