Ln106 ln130r powersteering rebuild main issue/cost.
All4Runner
Unread post by All4Runner » December 21st, 2017, 11:52 pm
I now have secondhand powersteering pump while old one is rebuilt in new year...fyi u buy a powersteering rebuild kit.. they do not come with main thread seal..the only thing that failed on mine. Removed repaired put back in and bad internal leak so part is ordered separate.. just so u know. Rebuild on powersteering main seal thread will only come out a couple times b4 failures ensue need to replace or rebuild separate part. Hope this helps.
