Hilux Speedo correction
Teamsherman
Unread post by Teamsherman » November 21st, 2017, 9:57 am
Hi folks,
I have recently upgraded my tyres from 31" to 33" and accoding to my speedo and a GPS speedo I'm out by about 6-7kph.
My car is a 2003 model 3.0Lt TD.
Can someone tell me how I can adjust my speedo so it is displaying the correct speed? I dont want my odometer to be incorrect either.
Alan.
Re: Hilux Speedo correction
Unread post by Peter Aawen » November 21st, 2017, 10:01 am
Unless your Speedo cable is gear driven (in which case you'll need to change the cable drive cog size!) then you'll need to buy a Speedo correction box (fm Mark's 4WD Adaptors? - $300ish) or make (Jaycar used to sell kits - $60ish) to convert the elect speedo impluses sent fm the trans into the necessary corrected frequency! :thumb:
Both the speedo indicated speed & the odometer/trip meter kms travelled readings will be corrected by a correction box/new drive cog, or as near to correct as you can get! Just remember tho, you can get away with having a speedo that tells you your speed is up to 10% faster than you are actually travelling, ie reads 110kph when you are actually only doing 100kph.... but our ADR's no longer permit ANY error the other way, ie reads 100kph when you are actually doing 110kph, or technically not even if you are doing just 101kph. :eek:
