GU Patrol overheating problem
Currently drive a 2.8lt Turbo diesel GU Patrol having an overheating problem, when pulling up hill. Has anyone had this type of problem or can offer advice on what it may be. Have replaced thermostat & fan clutch.
Unread postby Cav » February 16th, 2006, 3:55 pm
Re:GU Patrol overheating problem
Maybe water pump. ??? The radiator and cooling system might need a good flush.
You havn't put big spotlights on the front lately that could be blocking air circulation?
Thats all I can think of at the moment.
Cheers Mick.
Unread postby Mick. » February 16th, 2006, 6:44 pm
I heard that sometimes the fins in the core of the radiator gets block so not letting the air flow through; so flush the fins out with water for two or three stubies ;)
Unread postby jkclowe » February 23rd, 2006, 11:11 am
Thanks for the help found the problem not so cheap though. Fan clutch stuffed, cracked head have to slow down on the grog for a while.
Unread postby Cav » February 27th, 2006, 8:06 pm
Return to Anything to do with 4WD's &/or related to Fourby's
Who is online
Users browsing this forum: anybot, BennyT50
  • Follow US
4wd Action Club
Member
Login
Join the Club
