15 inch rims on a 80 series cruiser
Gezza 80 series
Unread post by Gezza 80 series » April 23rd, 2012, 12:46 pm
Hey guys just wondering anyone would know if 15 inch rims will fit on a 80 series cruiser
cac
Re: 15 inch rims on a 80 series cruiser
Unread post by cac » April 23rd, 2012, 1:49 pm
depends what year model it is, as there were larger brakes fitted in I think 1994 which required 16in rims....
LN106 Hilux Project
Gezza 80 series
Unread post by Gezza 80 series » April 23rd, 2012, 2:18 pm
It's a 1997 standard model and the rims are off my 1988 YN67 hilux so they are deep dish rims
Unread post by BigDutchy » April 23rd, 2012, 2:29 pm
I am quiet sure that its the diameter of your brakes requires 16" rims. I also think that the ofset might be wrong
acheshifter
Unread post by acheshifter » April 23rd, 2012, 11:03 pm
Yep, 16" rims a must for you. I have the same model, same year, and as Cac said, the later models have the larger brakes so came with 16" rims standard (albeit split rims). The offset should be -13 if you use a 16x8" rim, which I am pretty sure is what the GXL standard Toyota rims are.
Cheers, Acheshifter
spag1
Unread post by spag1 » April 24th, 2012, 1:16 pm
would any of you guys know if a 15x8 inch rim with 0 offset would fit an early 80?
i have a 92 model that came with 15s and upgraded to the factory 16x8 steel rims for my everyday tyres. but i can get a set of 15x8 hilux rims off a mate for free to use for play tyres.
any ideas guys?
james
spag1
Unread post by spag1 » April 28th, 2012, 1:40 am
anyone know?
Tractor88
Unread post by Tractor88 » April 28th, 2012, 3:02 pm
We have a 1992 80 Landcruiser GXL with 15x8 Sunnies 0 offset and 32 x 11.5 muddies. No probs at all as this year model came from factory with 15 inch rims.
Cheers.
spag1
Unread post by spag1 » April 28th, 2012, 3:06 pm
cheers mate, yeah i knew they came with 15s, but i was told they were 7" wide and wasnt sure on the offset, just thought id check
