Which Transfer Case Output Shaft Rear Bearing Type?
keep_on_runnin
Unread post by keep_on_runnin » August 4th, 2017, 7:46 am
Gidday Chaps,
I'm replacing my leaky seal on my Transfer Case Output Shaft Rear. Thought I'd change out the bearing too. My 80 is PART TIME and has a transfer case HF1A model in it. What type of bearing will I need and what number? I've searched and cant find a definitive answer. Is it taper bearing 90366-60008 or roller-ball bearing 90363-50005?
Mark
Return to “80 Series”
