What did you do to your 60 today?
thommo60series
Unread post by thommo60series » March 31st, 2010, 9:31 pm
today my old girl got some extended breathers as the original ones were leaking good enough excuse for me the rear one goes up front nicely in the chassis rail so l found out also put balance pipe between gear box and transfer case. you know the only problem with buying a 2nd or third hand rig is the bugger that owned it before you god had they stripped the filler plug on the transfer case and done it up with super human strenght anyways all done what has every one else done today:truck:
jason tincey
Unread post by jason tincey » March 31st, 2010, 11:08 pm
today i made wheel arch flairs out of garden edging and re-sealed my door archs. preparing for winter :)
hj61, 2" lift, 33" muddys, 13 psi boost, custom rear bar and sliders, top mount intercooler and lime green so cant be missed!
MUD666
Unread post by MUD666 » April 1st, 2010, 8:46 am
organised all the stuff to build my new center console for the weekends work :)
and also my kill switches :)
60Series.2H.Turbo.Lockers.Lift And 35 BFG'S!!
ITS PLAY TIME!! Environmental Terrorist Style!
Cheers Yoda Engineering
RuMBoZ
Unread post by RuMBoZ » April 1st, 2010, 1:17 pm
I just got some dome top allen key bolts for the wheel arches so now when I get flex it will not eat out my tyres! I also extended the breathers for the diffs. Does the gearbox and transfer case have breathers? If so, where should I look? If yes, I will do that as will :D
Chris
thommo60series
Unread post by thommo60series » April 1st, 2010, 2:33 pm
wanting to my gear box as well l believe the breather is right up top some where god l need to get a full workshop manual just learning about these yota's but this is what this forum is good for can any one shed some light on where g/box transfer breathers are located cheers.
good to see the 60's getting the attention they need
MUD666
Unread post by MUD666 » April 1st, 2010, 3:30 pm
they are right up the top of the gearbox mate real hard to get to would have to drop the box down
RuMBoZ
Unread post by RuMBoZ » April 1st, 2010, 5:44 pm
Hmm will in light of where they are, I think I'll pass on them this week. Have you guys done yours? Or are you not worrying about them because they are a bit hard to get too?
Maybe you can get to them through the shifter hole?
One thing I do want to do soon is the 'balance line' tube, which runs from the transfer case to the geabox, to prevent the issue of the gearbox oil draining into the transfer case. There is a thread on it now, just need some more info and pics before I do it.
Chris
Sixtys Guy
Unread post by Sixtys Guy » April 1st, 2010, 6:58 pm
The gearbox breathes thorugh the top where the shifter is. The transfer breather is on top, but it isn't a barb, it is a small one way valve )kind of hard to explain). The trick is to drill it out and tap a thread and put in a threaded barb fitting and run the breather off that. Transfer needs to be dropped out to do this.
AKA Mark.
HJ60-Lock Rights, OME springs, 5125 Bilsteins, 2" BL, 33 FCII, Longfields, 4.56 gears, Ironman winch, custom sliders.
http://www.4wdaction.com.au/forum/viewtopic.php?t=17712
1976 FJ55 - Stocko, except for Bilstein Shocks & power steering
http://www.4wdaction.com.au/forum/viewtopic.php?f=22&t=55716&hilit=fj55
1975 FJ55 - Unregistered project!
Lugh
Unread post by Lugh » April 1st, 2010, 6:59 pm
I didn't do anything to mine today - It's perfect already. :D
The dumber people think you are, the more surprised they'll be when you turn around and kill 'em.
[url=http://www.4wdmonthly.com.au/shed/index.php?id=56&im=1]My shed - LUGH[/url]
Red04VXE
Unread post by Red04VXE » April 1st, 2010, 7:21 pm
Nuthin till next wednesday. Will be putting axle back in and rear hub together. Then making up light bar for roof and fitting new int light.
RuMBoZ
Unread post by RuMBoZ » April 1st, 2010, 7:26 pm
I have to thank Lugh for the "dome top allen key bolts for the wheel arches" tip! He told me that one on the 60 seriesforum meet up.
thanks mate :D
Chris
Red04VXE
Unread post by Red04VXE » April 1st, 2010, 7:29 pm
Yeah i found the ones i looked for, inthe mrs commondoor.
whitelighting
Unread post by whitelighting » April 2nd, 2010, 6:22 pm
Fitted front west coast suspensions springs today just waiting for u bolts for the rear it well be interesting to see how they flex. Got them for $300 from the wreckers look's almost new.
Lugh
Unread post by Lugh » April 2nd, 2010, 6:30 pm
No worries mate. :thumb:
Sixtys Guy
Unread post by Sixtys Guy » April 2nd, 2010, 6:56 pm
whitelighting wrote:Got them for $300 from the wreckers look's almost new.
Score!
AKA Mark.
Return to “60 Series”
