HOW TO: 2" 60 Series Bodylift
good old 60
Unread post by good old 60 » February 8th, 2010, 9:21 pm
thanks guys this little bit of info made the lift og the old girl just that much easier. i would never of found the very back bolt inbehind that cover if it was not for you guys. now the old girl looks alot more in proportion with the 35's.
12ht, 11 psi boost, 35" cooper 2"body just waiting for 4" rhino kit to come.
mudshark
Unread post by mudshark » March 5th, 2010, 6:52 pm
hey guy's would anyone recomend either alloy or plastic lift blocks all opinions gr8ly appreciated.
chrisso83
Unread post by chrisso83 » March 5th, 2010, 7:52 pm
i think ill be goin ally mate.
toy yoda
Unread post by toy yoda » March 8th, 2010, 4:55 pm
i use ally
trevors bj
Unread post by trevors bj » April 7th, 2010, 6:50 pm
What springs are you guys running with the body lift? I have been looking at going with 4" springs which turn out to be 2" inch with extended shackles and need extended brake lines and castor wedges. But looking at this thread body lift might be the go. How tall are the actual blocks? I could turn some up on a mates lathe myself and save a few bucks.
Thanks Trev
toy yoda
Unread post by toy yoda » April 8th, 2010, 5:36 pm
the blocks are 50mm (x 60mm aprox wide) they sit on the oem rubber blocks
generally a 2"lifted spring is the norm for a 60...shackles can be used also
there are rules for lifting and how you achieve height, but ext shackles are 100% illegal outright in all states!
they are extremely obvious to police and a 2" ext shackle only gives 1" extra lift.....
trevors bj
Unread post by trevors bj » April 9th, 2010, 6:16 am
Cheers for that 2" springs and 2" body it shall be.
whitelighting
Unread post by whitelighting » April 9th, 2010, 7:02 am
mudshark wrote:thnx heaps Mark i want to do this soon and this guide is very helpful, i was thinking of using the poly mounts and leaving out my rubber ones as they are a bit deteriorated and just ending up with a 1" lift. but from reading this i assume that is not poss. now i think i will have 2 search for original rubber mounts as well (any hint where?) brake lines would have to be lengthened as well ? yes ? no ?. thnx HEAPS guys this info is gr8. :)
just get 3" poly bocks off ebay and remover rubber mounts. The bocks I got for mine were only $90 had no problems at all and I treat my car like crap.
toy yoda
Unread post by toy yoda » April 9th, 2010, 8:25 am
whitelighting wrote:just get 3" poly bocks off ebay and remover rubber mounts. The bocks I got for mine were only $90 had no problems at all and I treat my car like crap.
not advisable.......all that will happen is you will punch the block through the floorpan
this has been done and that happened time and time again
the rubber blocks do absorb a lot!
TUFF HJ60
Unread post by TUFF HJ60 » May 26th, 2010, 7:00 pm
Gumby wrote:Very good wright up... lol i swear ive seen it before when i done my body lift years ago... maybe ih8mud, none the less we need it as a sticky i think... what ya think mods...
I reckon your body lift was done and dusted in a couple hours from memory!!:D
toy yoda
Unread post by toy yoda » May 26th, 2010, 7:09 pm
only if you both had tonselitis;)
Sixtys Guy
Unread post by Sixtys Guy » May 26th, 2010, 7:50 pm
Thats because I emailed it to you when your were doing yours! And yes, as I pointed out in the orginal post most of it is taken from IH8Mud.
AKA Mark.
HJ60-Lock Rights, OME springs, 5125 Bilsteins, 2" BL, 33 FCII, Longfields, 4.56 gears, Ironman winch, custom sliders.
http://www.4wdaction.com.au/forum/viewtopic.php?t=17712
1976 FJ55 - Stocko, except for Bilstein Shocks & power steering
http://www.4wdaction.com.au/forum/viewtopic.php?f=22&t=55716&hilit=fj55
1975 FJ55 - Unregistered project!
LZ_Pan
Unread post by LZ_Pan » July 10th, 2010, 10:23 pm
i am considering installing BL on my hj61 automatic truck. has anyone ever considered bimetallic corrosion over time due to the aluminium being in direct contact with the steel? Is there some kind of a rubber damper that can be used to keep the metals separated? maybe the oem rubbers? also any feedback on mods needed when lifting 2" automatic box? pan
1984 HJ60
1988 HJ61
2003 HDJ78
Bushmiester
Unread post by Bushmiester » August 20th, 2010, 8:28 am
If you've got a dollar take the shroud and fan off and put thermo's on. It should add a horse or two to the team.
Bushmiester
Unread post by Bushmiester » August 20th, 2010, 8:34 am
Return to “60 Series”
