more power
peppa dog
more power
Unread post by peppa dog » January 4th, 2015, 6:47 am
Hi guy's,i after more power from my 2h motor and would like some opinions or advise if turbo charging the motor would be the best way to go? the motor has 412 000 km's on it. Thank's.
stockhorse
Re: more power
Unread post by stockhorse » January 4th, 2015, 9:41 pm
turbos on 2h's is a common upgrade and one that works well. That is a reasonable amount of k's on the motor and I would check it out well before fitting a turbo. When was the pump timing ,injectors etc done? have you had a compression test done?
Neat 60 is in the process of doing a turbo upgrade and the exhaust manifold has presented some issues for the type of instal he is after. Check out what is available and what type of install you want to do before committing to it.
peppa dog
Re: more power
Unread post by peppa dog » January 7th, 2015, 7:11 pm
thank's for your reply,will consider my options.
nilla60
Re: more power
Unread post by nilla60 » January 7th, 2015, 8:44 pm
If you do, keep the boost mild. Even a small amount of boost transforms the 2H (in that it is not a total slug on the first uphill incline), but resist the urge to crank the boost if you want a reasonable life span (and start with a strong motor and keep an eye on EGTs). If you are not seeking a million kilometre motor, a turbo is probably the most cost effective option this side of a 12ht swap (still very pricey) or vehicle upgrade.
LZ_Pan
Re: more power
Unread post by LZ_Pan » February 10th, 2015, 9:15 pm
While onroad the difference is very noticable, when in 4wd and especially low range the slow 2H is no worse then 12HT.
Return to “60 Series”
