Where are Power Window fuses on Sahara
aboutfivebucks
Unread post by aboutfivebucks » February 16th, 2012, 5:02 pm
Hi all,
Does anyone know where the fuse is for the power windows and the sun roof on a 1989 Sahara HJ61. Both stopped working today and there's no mention of power windows or sun roof in the Gregory's manual.
Any other troubleshooting advice is welcome
Gav
aboutfivebucks
Re: Where are Power Window fuses on Sahara
Unread post by aboutfivebucks » February 16th, 2012, 9:41 pm
all sorted thanks to the exploroz forum.
there is no fuse - there is a circuit breaker next to the other fuses, reset with pin.
1988HJ-61
Unread post by 1988HJ-61 » January 9th, 2016, 8:21 pm
Hi Myhj61 has just lost all power to the windows what did you do to solve your prob?
stockhorse
Unread post by stockhorse » January 9th, 2016, 8:56 pm
the bottom silver cylinder marked power can be reset with a paper clip, try that one. If not I'll look up the wiring diagram for you.
1988HJ-61
Unread post by 1988HJ-61 » January 9th, 2016, 9:35 pm
Hey Stockhorse thanks for the reply everything matches up to the tee I have the same cover as well the two circuit breakers heater at the top power at the bottom I can see a little hole on them both is this where I poke the paper clip? I pulled the power circuit breaker out ...
stockhorse
Unread post by stockhorse » January 9th, 2016, 10:16 pm
Yes mate you should here a faint click if it resets but it is easy to not hear it
1988HJ-61
Unread post by 1988HJ-61 » January 10th, 2016, 10:47 am
Cheers Mate worked a treat, thank you for your help :)
stockhorse
Unread post by stockhorse » January 10th, 2016, 2:29 pm
No worries ,now you can wave out the window when we pass on the tracks.
Return to “60 Series”
