2h shut off problem
71 Lil Greeny
2h shut off problem
Unread post by 71 Lil Greeny » February 24th, 2015, 1:11 pm
I bought a fj40 with a 2h dropped in it ive fixed most problems with it but the EDIC (electronic diesel injection control) has not been wired in ive got 4 wires green yellow red and blue i can't find what they wire to i brought a 2h workshop manual doesn't show where they connect to
Can anyone please help
Rogers Cruiser
Re: 2h shut off problem
Unread post by Rogers Cruiser » February 24th, 2015, 2:19 pm
The relay (under the dash/near the glove box) has inputs from the ignition, low oil ect. and that wires to the EDIC motor behind the Injector pump. The EDIC motor has an arm which controls the fuel level of the pump (overfuel/normal/no fuel-Stop)
What wires where are you refering to?
Jimmy Wood
Unread post by Jimmy Wood » February 25th, 2015, 8:30 pm
Like Roger said, you need to find the EDIC relay which is a little silver box like the glow relay, and they go to there. Most likely they never installed it when they put the 2H in, and they are probably hard to come by now as well.
Simplest thing to do would be to wire up a manual cable to shut off or try and locate an EDIC relay and get a HJ47 or HJ45 wiring diagram. Or HJ60 but probably more complex than the 45 or 47.
Maybe, if you are pretty electrically minded, make a system of electric actuators to move the fuel control lever, or make your own EDIC relay, but remember that it has 3 positions, Off, Run and over injection for starting. The EDIC motor has a ball switch system and more info can be found on the ih8 mud forum
71 Lil Greeny
Unread post by 71 Lil Greeny » February 26th, 2015, 9:23 pm
Thanks for the replys guys
This pic is the head buster one is full time active but the three others we dont know where connect to i will past them through a relay but what they connect from there
My guess is one would be oil pressure/ other might be ignition the third i wouldn't have the a clue
The my workshop manual wire diagram doesn't have the in it
Rogers Cruiser
Unread post by Rogers Cruiser » February 26th, 2015, 9:53 pm
mate, where is that comming from?
and is there anything plugged into the EDIC motor?
Jimmy Wood
Unread post by Jimmy Wood » March 2nd, 2015, 10:31 am
Its pretty simple, there are four wires which run from the EDIC relay to the EDIC motor. There will be others for oil, ignition etc but they feed into the EDIC relay under the dash, so not likely in that bunch you are showing.
If you have the EDIC relay installed, just run the wires from that to the EDIC motor on the engine block.
Check out the I H8Mud forum.
71 Lil Greeny
Unread post by 71 Lil Greeny » April 18th, 2015, 10:15 pm
sorry for the late reply work got a bit out of hand so the fourby had got push back
thanks for the help i think i found a wiring diagram from edic relay(fuel control relay) to anything else
cheers guys for the help
Return to “40/55 Series”
