Having problems with HJ47 air con wiring - Help!!
philbo
Unread post by philbo » October 10th, 2013, 2:33 pm
I have purchased and am tring to fit a 2nd hand AC to an 81 hj47 with no luck. The AC loom mostly connects to only AC components and so is pretty self explanitory but I have two problem connections
1) a 3 pin plug with bw, lr and lw wires into it
2) an individual lw wire with no plug
I cant figure out where either of these plug into the rest of the loom.
Any advice or photos from someone who has one fitted would be appreciated
oversite
Re: Having problems with HJ47 air con wiring - Help!!
Unread post by oversite » October 10th, 2013, 2:43 pm
mate, post a couple of photos and ill try to help. I just cant figure out what you are on about without photos.
philbo
Unread post by philbo » October 13th, 2013, 1:51 pm
OK sorry for the delay, here is a photo of the AC wiring loom I was given, as well as the wiring diagram I am trying to work off.
The two that I cannot figure out are the unknown wire and unknown plug. These must plug into the main loom of the car somewhere but I can't figure out where.
philbo
Unread post by philbo » October 13th, 2013, 1:53 pm
Excuse the masking tape all over the loom, I have been trying to figure out how it all ties together by using a multi meter and then marking what each wire connects to.
Return to “40/55 Series”
