Which Suspension Are You Using?
TThwaite
Re: Which Suspension Are You Using?
Unread post by TThwaite » April 13th, 2014, 11:05 pm
I'm looking to replace the shocks on my truck, I have been running ProComp shocks for the past 12months, but the bushes have worn completely so I won't be buying those again!! Has anyone got anything to add about the Ironman Foamcell shocks?? HurricaneNT - did you find other shocks for the front after the fitting issue??
Lifted 2006 Ford Ranger Wildtrak
BigMitch87
Unread post by BigMitch87 » April 21st, 2014, 2:31 pm
Have been running Ironman Foam Cell with Ironman HD Torsion Bars and leaf packs for the last 8 months. In that time have gone off road nearly every weekend and snuck in a 2 week trip to Cape York. Everything seems t be going fine and was able to get all this supplied and fitted for under $1,700 (Fast Fit Exhaust in Townsville in case you were wondering). Would get this same kit again without thinking twice about it.
2006 Mazda Bravo 2.5TD - Airtec Snorkel - Dual Battery - 55w HID Ebay Specials - Mickey T ATZ's - TJM Alloy Bar - GME TX3220 UHF w/6dB whip aerial... To Come - Lift - Sliders/Steps - Remove the canopy and replace with custom unit with rooftop camper.
Cape Trip in August 2013
jvb
Unread post by jvb » May 19th, 2014, 1:25 pm
Does anyone know if the Monroe GT Gas are any good? They are cheap, $160 per set on eBay.
I don't want to spend a lot, the only off-road stuff I do is in a paddock and some dirt tracks.
Also looking at the Tough Dog torsion bars from the same seller for $225.
2014 BMW X3
2004 PH Courier 2.5TD
1973 T140V Bonneville
1954 Zündapp 250 Elastic
jvb
Unread post by jvb » September 21st, 2016, 8:36 am
Two years later and I finally installed some Monroe GT shocks and the Tough Dog torsion bars.
Needed a press to remove the old torsion bars.
The Tough Dog bars make a significant difference. With the same ride height there is much more suspension available than with the factory fitted ones.
Ride is much smoother now.
2014 BMW X3
Return to “Courier / Raider”
