Got (or want?) bigger tyres? Come in here!
hoyks
Re: Will PX ranger rims fit on a PE Courier?
Unread post by hoyks » January 1st, 2016, 3:36 pm
Ford: Courier 4x4
PCD 6/139.7, Offset OE 10/20/25
Ford: Ranger (4x4), PX, 2011 Onwards
PCD 6/139.7, Offset OE 55 Pos
dimensions from;
http://www.csadirect.com.au/fitment-gui ... t2Id=6&T=0
So, probably not.
I know they are not interchangeable on the tyre carrier I built to fit a PD Courier tyre and rim. On the carrier the old tyre/rim combo would clamp up tight against the mount, with the new rims I can't even get the studs to show through the rim center.
DangerPE
Unread post by DangerPE » January 1st, 2016, 7:27 pm
spewin, thanks mate.
just trying to find a cheap set second hand.
only the newer models seem to have something decent for sale at a cheap price
2002 Courier 2.5 turbo
2005 Patrol 4.2TD
hoyks
Unread post by hoyks » January 1st, 2016, 7:53 pm
Before 2011 will fit, after, nope. sorry.
But you aren't stuck with Courier/B-series rims. Pajero/Triton, Rodeo, Hilux (some), Colorado (I think) all fit, and probably others.
I got a set of 15" rims off a Hilux, strapped 30x9.5R15 tyres on them and put them under my Courier. You may need to get some Hub locating rings (CBL Rings).
http://www.csadirect.com.au/pdf/Bulleti ... _Rings.pdf
DangerPE
Unread post by DangerPE » January 2nd, 2016, 4:13 pm
awesome thanks mate.
will expand the searching.
2005 Patrol 4.2TD
Boxhead 71
Re: PE courier - what's the factory tyre size?
Unread post by Boxhead 71 » January 26th, 2016, 8:55 pm
DangerPE, 16x6 I reckon, on the base model at least. With 205R16 tyres.
gros21
do 31's fit on a stock b2500?
Unread post by gros21 » April 19th, 2017, 2:07 pm
it seems cheaper to scrap the 16's and go 15's and 31's but will they fit on a stock b2500
Return to “Courier / Raider”
