Got (or want?) bigger tyres? Come in here!
jonnie247
Re: Anyone fitted 33x10.5? What is the gearing be like?
Unread post by jonnie247 » July 13th, 2012, 12:05 pm
Well i have no problem with power. Im runnjng gas aswell and in the wet i can get my cooper stt's spinning in third! And im doing exhaust and tune at roo systems soon so i think she would be able to handle it. Are bf goodrich muddies any good? Or anyone else no of a 33x10.5 muddie thats good?
bravoboy300
Unread post by bravoboy300 » July 14th, 2012, 5:47 pm
I have 31 MTZs which are bloody good in my book, but they are my first muddie, maybe have a look in wheel and tyre
gunnabuild1
Will Courier Wheels fit my Bravo? What about Offset?
Unread post by gunnabuild1 » November 26th, 2012, 9:58 pm
Hi looking for some stocker rims for my 95 Bravo,found some locally that came off an 02 Courier, will they fit my Bravo, does anyone Know? Read a bit about different offsets but not sure to which they apply.
Just want to replace the mags that came with the vehicle.
DamoG
What's the max legal size wheels in Qld?
Unread post by DamoG » April 4th, 2014, 7:03 pm
Can anyone tell me what the max legal wheel size is in Qld? Someone said only 5% larger than standard :(
MasterInnovator
Re: What size wheels in Qld?
Unread post by MasterInnovator » April 4th, 2014, 7:10 pm
its only a max of 50mm increase in diameter as far as I am aware of
tanz
Re: What's the max legal size wheels in Qld?
Unread post by tanz » April 4th, 2014, 9:26 pm
As stated above, for a 4wd, tyres are allowed 50mm larger diameter and 1.5x the original width.
Jer2000
Unread post by Jer2000 » April 5th, 2014, 12:29 am
And these calculations are based upon the largest wheel/tyre the manufacturer fits too. Which is not necessarily the one fitted to your 4wd from the showroom!
DamoG
Unread post by DamoG » April 5th, 2014, 12:55 pm
Cool thanks. So on a 2001 ford courier twin cab TD does anyone know how big I can go? Not sure what the largest factory tires were
MasterInnovator
Unread post by MasterInnovator » April 5th, 2014, 3:40 pm
Check on your door(driver side) there should be a tyre placard...it will state the nominal tyre size for that vehicle...that size is the size you go off for your 50mm max diameter increase
sinkerz
Will Ranger 16" rims & 265/75/16 AT's fit my 03 Courier?
Unread post by sinkerz » July 20th, 2014, 5:03 pm
hey guys i have bought a 2003 TD ford courier 4x4 and I'm thinking of getting some 16" ranger steel rims with 265/75/16 all terrain tyres fitted to it just wondering if they will fit without a lift kit and have minimal scrubbing? i was told 15" might not fit due to the big drum brakes on the rear. cheers ryan
hoyks
Re: Will Ranger 16" rims & 265/75/16 AT's fit my 03 Courier?
Unread post by hoyks » July 20th, 2014, 5:36 pm
I had a 98 model and fitted 30x9.5 R15's onto it. They fitted over the front calipers and rear drums no worries at all. For the rubber, there was heaps of room and never scrubbed so 265's should work. I don't think too much in the final drive line changed between the two models.
I don't know if the 16" rims off the current model would work though. I think the off set is different as i have a tyre carrier on the camper that I built. It fitted a standard courier rim and tyre no issues at all, it would clamp down onto the carrier and sit flush against the back wall of the camper.
I tried to mount a current model Ranger/BT50 steel rim onto it and I couldn't even get the studs to show through the holes. That would be around 3" difference between the 2 rims.
Matt_Raider50
Unread post by Matt_Raider50 » July 21st, 2014, 12:40 am
Check the diameter of the centre hole on the rims I think the rangers may have a smaller hole that goes around the hub, it might be the same if yours doesn't have manual locking hubs. 15's should fit thats what I have on my courier and Im pretty sure some of the rangers an BT50s even had 15 inch steel rims as standard.
DangerPE
PE courier - what's the factory tyre size?
Unread post by DangerPE » December 28th, 2015, 7:48 am
Hey guys
What's the factory rim/ tyre size for a Pe 4x4?
Found a few different sizes listed on the net.
I'm looking for a set, trying to save the muddies for off-road only.
Kaine
2002 Courier 2.5 turbo
2005 Patrol 4.2TD
hoyks
Re: PE courier - what's the factory tyre size?
Unread post by hoyks » December 28th, 2015, 9:21 am
It should be on the tyre placard on the drivers door/door jam.
16x7 for the rim, not sure on the offset.
DangerPE
Will PX ranger rims fit on a PE Courier?
Unread post by DangerPE » January 1st, 2016, 10:46 am
Hey guys can't find this info anywhere on the net.
Will Px ranger rims/ alloys for on a PE courier in terms of offset ect?
265/65/R17's I'm looking at.
Currently got 32 big horns
2005 Patrol 4.2TD
Return to “Courier / Raider”
