Ranger / BT50 - New &/or Old - Known Problems
oncedisturbed
Re: Ranger / BT50 - Known Problems
Unread post by oncedisturbed » December 25th, 2011, 9:16 am
same here as Fred mentioned at 123k
reilly820
Unread post by reilly820 » January 17th, 2012, 10:51 pm
i have 2011 bt50, after about 20000kms squeeling from front drivers wheel, started only in cornering and then progressed to constant. took it to mazda and they said its a common problem where there isnt enough grease in the wheel bearing from the factory. fixed under waranty no worrys.
JBird
Unread post by JBird » February 20th, 2012, 4:16 pm
Added some updates for the latest models.
"Failure is never quite so frightening as regret"
JBird
Unread post by JBird » February 20th, 2012, 4:17 pm
bozo21
Unread post by bozo21 » February 20th, 2012, 5:17 pm
JBird wrote:Anyone happen to know the equivalent models for the BT50 ie: PJ Ranger = ? BT50?
Also, would anyone be familiar with what years the different models ran for ie: PJ Ranger - 07 to 09?
Great idea mate.
I have a 12/09 BT and its the updated version. Like the PK, i think from what i have read the updated model was start of 2009??? Not positive but, alot of the parts places have parts listed as 2006-2008 and then 2009-2011 so maybe its right.
JBird
Unread post by JBird » February 21st, 2012, 3:53 pm
Cheers bozo.
Yeah, dunno what Mazda call their different BT-50 models but I have added the production years for reference anyways.
machined
Unread post by machined » February 22nd, 2012, 4:57 pm
what happen to PK cruise control fix? ford says early 2012...
JBird
Unread post by JBird » February 23rd, 2012, 3:50 pm
Couldn't tell you mate, I have a PJ with an aftermarket Autron Auscruise fitted. Maybe give your local dealer a call and ask.
m6sports
Unread post by m6sports » February 23rd, 2012, 10:03 pm
machined wrote:what happen to PK cruise control fix? ford says early 2012...
The PX came out now ford doesn't care anymore
My camper trailer build
viewtopic.php?f=134&t=125437
machined
Unread post by machined » February 25th, 2012, 6:13 pm
wouldnt be surprise it is ford indeed...
JBird
Unread post by JBird » February 25th, 2012, 10:26 pm
Yep, sounds like it would be a typical Ford reply:
Customer - "Yeah hi, just enquiring about what's going on with the PK cruise control fix?"
Ford Dealer - "Sorry sir, haven't heard anything about that but maybe you'd be interested in purchasing one of the new Rangers; they come with cruise standard"
:D
mattygbt50
Unread post by mattygbt50 » May 18th, 2012, 12:41 am
kemu wrote:2008 BT-50 Freestyle. starting problems. turned out to be crank angle sensor. about 4th case of this that i have heard about locally. other than that runs like a dream. as for the front diff issues, none so far but would have to agree with gecko270. if you dont fit better breathers or at least check them regularly. you askin for trouble.
Brilliant this is what turned out to be wrong with mine took Mazda 4 days to find the problem
MBJG
Anarchist
Unread post by Anarchist » June 21st, 2012, 1:50 pm
Hey all I just brought an 08 ranger and cant find any threads on anyone doing the 120 thou service anyone got any insight?
Ive done 110kms but i want to get some info to get myself ready for it
Keen for some pms if anyone wants to talk tech and cant be bothered going to the 'designated' threads to do so
JBird
Unread post by JBird » June 21st, 2012, 4:58 pm
Hey mate,
Timing belt & tensioner need to be replaced at 120k; more reading here.
Big Wrigg
Unread post by Big Wrigg » July 5th, 2012, 12:07 am
Anyone noticed or had any issues with oil leaks?
I have just ticked over 35000klm and noticed that there has/is a slight leak at the rear of the head/block gasket that has run down the back of the engine over the gear box. doesnt look terrible at the moment. But cant be a good thing on an 18mth old car right?
This is something that should be covered by warranty right?
By the way cruise control is now back online... FORD RELEASED THE KITS FRIDAY 29/6/12 according to my dealer anyway.
Return to “Ford / Mazda”
