Fatal 200 series flaw - chassis cracked & car written off!
Newelly1
Re: Fatal 200 series flaw - chassis cracked & car written of
Unread post by Newelly1 » October 15th, 2015, 12:27 pm
Yes 4wd hobbit, it would be wonderful to hear if anyone else has had this issue too
4wd Hobbit
Unread post by 4wd Hobbit » October 15th, 2015, 2:15 pm
It would seem it is not an issue with the 200 series so something relevant to your vehicle rather than something systemic.
Newelly1
Unread post by Newelly1 » October 18th, 2015, 11:38 am
The fact is though those mounting points were never going to be capable of holding a bulbar such as this and whether by oversight of ironman in not fixing the bar to the vehicle as per regulation or Toyota for designing a system that is not capable of completing the task that it is designed for.... One of them is at fault
4wd Hobbit
Unread post by 4wd Hobbit » October 18th, 2015, 2:07 pm
Newelly1 wrote:One of them is at fault
Or operator error.
Newelly1
Unread post by Newelly1 » October 21st, 2015, 1:05 pm
It is a bit hard to be an operator error, he hasn't touched the bulbar, so if driving a car around fitted with a bulbar that has been attached by a third party (Ironman), not having altered it at all, I would have to question that seriously
4wd Hobbit
Unread post by 4wd Hobbit » October 21st, 2015, 6:05 pm
Well if it was systemic then others would be having the problem.
nilla60
Unread post by nilla60 » October 23rd, 2015, 4:32 pm
I can see four potential contributors:
- Butt mount with a large, forward projected load ala winch cradle = leverage
- Any play or poor fit in mounting allowing more movement and vibration (was it installed correctly by the dealer?)
- Combine the first two with longer duration on corrugations than most people
- Add a few snatch recoveries to start and/or aggravate any cracking
In comparison, the bar on my 105 has a sleeve mount that overlaps 200-300mm of chassis rail.
Bugger. :(
Newelly1
Unread post by Newelly1 » November 22nd, 2015, 3:13 pm
Thanks for your response nilla, it is a bit of a bugger....
Return to “Toyota”
