can 35's fit under a bundera with a 2" lift?
GQ SWB patrols rock
Unread post by GQ SWB patrols rock » August 19th, 2012, 7:41 pm
hi guys, i was just wodering if i could run 35 inch tyres under my bundy. i am only running a 2 inch lift. Also can i change my 15 inch rims to 16 inch rims? thanks :)
rolly82
Re: can 35's fit under a bundera with a 2" lift?
Unread post by rolly82 » August 19th, 2012, 7:57 pm
without any suspension work,i'm going to say "No".
GQ SWB patrols rock
Unread post by GQ SWB patrols rock » August 19th, 2012, 8:17 pm
thanks for the fast reply, and so did you mean even with the 2 inch suspension lift they wont fit?
muzza01
Unread post by muzza01 » August 19th, 2012, 8:21 pm
No mate not a chance.
Probably should put your thread in the Toyota section. ;)
105 Series Turbo Diesel Cruza, 3 inch mandrel Taipan exhaust, BFG Km2's, 12K lb winch. 3 inch lift. Steel rear bar and twin wheel carriers. Dual Batteries with monitor, Brush bars, side steps, Roof Rack, Cargo barrier, UHF.
http://www.4wdaction.com.au
rolly82
Unread post by rolly82 » August 19th, 2012, 8:22 pm
You'll probably need more then 2" of lift on the bundy to fit 35" tyres,
IMO,you'll need about 4" lift....maybe more.
Unread post by Peter Aawen » August 19th, 2012, 10:10 pm
Or maybe a 2" lift & cutting the guards a fair bit..... :D
PS, moved it from Chit Chat & put it into the Toyota General Tech section! ;)
toy yoda
Unread post by toy yoda » August 19th, 2012, 10:21 pm
i can scrub 33"s on a 4" lift if i try hard enough!!
GQ SWB patrols rock
Unread post by GQ SWB patrols rock » August 19th, 2012, 11:19 pm
thanks guys :)
Bundy35s
Unread post by Bundy35s » March 11th, 2014, 9:41 am
I have 35x12.5r15 on an RJ70 with a 4" lift an no sway bars haven't scrubbed yet.
The only problem I've really come across is a top speed of around 95-100kmh lol so I recommend a motor upgrade
www.marks4wd.com/catalogsearch/result/?q=RJ70+Bundera
Follow this link these guys have everything you need/ want for engineered conversions
As the 22r can have a hard time turning 'em.
Return to “Toyota”
