4runner tappet cover oil leaks
skik
Unread post by skik » June 11th, 2015, 4:53 pm
Hi guys
i have a v6 4runner with leaking tappet cover gaskets have ordered a new set was wondering if shortening the bushes the bolts run through to increase clamping pressure slightly will make a difference the last time i did the gaskets i ran a bead of silicone around them but didn't seem to make any difference
any ideas would be greatly appreciated
thanks
Re: 4runner tappet cover oil leaks
Unread post by mydmax » June 11th, 2015, 5:41 pm
silicon is often not much chop. Try using Loctite 516 Red plastic sealant. On clean oil free surfaces it does a very good job.
skik
Unread post by skik » June 12th, 2015, 12:03 pm
thanks Mydmax will have to see if i can get any locally being in a small town theres not a lot of options
chris_stoffa
Unread post by chris_stoffa » June 12th, 2015, 3:13 pm
And don't clamp it down too tight. Finger tight only at first to allow the sealant to set and take form.
Then torque it down to the correct spec - many over tighten the bolts too far too fast and it just squeezes everything out.
03 Bravo 2.5TD DCab
skik
Unread post by skik » June 12th, 2015, 4:16 pm
on the 3vz's it has like a Colette that runs through the tapet cover and pills down tight on the head my thoughts where that it dosen't allow quite enough clamping pressure but will keep in mind the initial tightening
Return to “Petrol Tech”
