1HZ Valve Clearances
JDs
Unread post by JDs » April 16th, 2011, 9:06 am
Hi all! I am about to do my valve clearances for the first time I am reasonably capable but would like to know if there is anything to look out for. My engine is getting a bit noisy around the 2200-2400 rpm mark no noise above and below these revs, I figure the clearances are too tight as they have never been done :crazy: 340,000kms now last 100,000 with a Turbo on it. I think I am lucky it hasn't gone "Bang" yet, pretty amazing really when the motor was not designed for it :o Must be attributed to regular oil/filter changes :) Thanks in advance :thumb:
GRIMACEGQ
Re: 1HZ Valve Clearances
Unread post by GRIMACEGQ » April 16th, 2011, 8:02 pm
hey mate they arent too bad to do im doing mine this week, (just converted it to turbo also 1hz)
they are the shim type so ive been told, you need two special tools to do it properly. but can also improvise haha .
i saw a video around here somwhere on how to do them! ill try dig it up
also off topic, what exhaust gas temps are you running?
GRIMACEGQ
Unread post by GRIMACEGQ » April 16th, 2011, 8:36 pm
JDs
Unread post by JDs » April 16th, 2011, 9:27 pm
Thanks Buddy I am just about to look at the link now! I don't know what my EGT's are but I did have it dynoed but there machine was a bit suss so I didn't get a proper readout, I have just fiddled with the pump screw a bit, up a bit down a bit whoops too much smoke! Down a bit, you know but thanks for the link I will check it out now! Cheers!
JDs
Unread post by JDs » April 16th, 2011, 9:32 pm
That is really great thanks heaps :thumb: :thumb:
lshobie
Unread post by lshobie » April 16th, 2011, 10:35 pm
Mate be careful fiddling with the fuel screw if you don't have a pyro guage - you could be running your temps pretty high.
I made that video by the way and I always do a valve shim adjust on the 1HZ's when I get them - they all need an adjustment it seems and it makes a difference on the egt's and engine noise.
louis
Return to “Diesel Tech”
