wj grand, electrical issues
Jeepers Unite
brimma
Unread post by brimma » March 21st, 2013, 8:44 pm
hi guys,
hope there is an auto lecki out there that can help?
been having issues with the battery going flat, if not used for a few days, (replaced) still goes flat?
every now and then, it wont idle, and stalls! it seems like the auto choke is not working properly? on the hwy, it seems to be missing? hard to pick? and just recently, the air con fan, works sometimes? most times not! last trip out, the abs light came on? but still had brakes,
its using a lot more fuel than usual,= choke not working properly, or a computer malfunction?
I suspect an earth connection problem some where! maybe?
any sugestions ????
BLU-125
Re: wj grand, electrical issues
Unread post by BLU-125 » March 25th, 2013, 7:25 am
I recently had a problem with strange electrical issues. Turned out to be the wiring loom had chafed on the steering column universal joint. The loom is supposed to be held away from the column by a bracket at the front of the RH head.
2004 GRAND CHEROKEE OVERLAND.
WHAT SIDE WAS YOURS ON IN WW2? :)
Return to “General Jeep”
