Help with Models
The original 4WD
Harb
Help with Models
Unread post by Harb » May 25th, 2012, 11:29 am
I may be in the market for a used Dual Cab with a Tub back for an upcoming project if it goes ahead
Can someone help me with the models and which are best....motors.....trans etc etc
Thanks for your help....this will be my first venture into LandRovers
garrycol
Re: Help with Models
Unread post by garrycol » May 25th, 2012, 12:16 pm
The obvious is one of the 130 Defenders - starting with the 200tdi from the early 90s, to the 300tdi in the mid to late 90s, then the TD5 from the early 2000s (all these have the r380 5 speed box except the 200tdi with had LT77 5 speed.
In the mid 2000s on was the Puma engined 130 with 6 speed manual. Also in the Puma models there is the 110 dual cab.
Garry
Harb
Unread post by Harb » May 25th, 2012, 12:22 pm
thanks Gary, so I take it the dual cab is named the 130 then (sorry I am totally new to LR)
I am looking for a rugged Mil Spec vehicle and not at all worried about flash interior as long as it has or can have a rear seat fitted....
SOmeone said they went to India and ford engines as a result..... when did that happen and should I avoid them
stretch4x4
Unread post by stretch4x4 » May 25th, 2012, 12:30 pm
Pretty sure 130 and 110 refers to the wheelbase..
you can get dual cab or wagon or single cab in most of the wheelbases I think..
Their website sort of gives the naming.. There used to be an ad couldn't find it but did find this:
Can't really help re the motors though :) Sounds like an interesting project though :twisted:
Image HDJ79R & Traxxas Summit
worthy
Unread post by worthy » May 25th, 2012, 12:39 pm
the ford engine is the Puma, same as in later transit vans. Pretty good, powerfull etc. Is a CRD though.
2000 Prado 3.0LTD Lifted and Locked
viewtopic.php?f=22&t=87167
Have IFS, Will Impress
Harb
Unread post by Harb » May 25th, 2012, 2:06 pm
Cool......thanks guys :thumb:
garrycol
Unread post by garrycol » May 25th, 2012, 8:56 pm
As mentioned the model designator is the wheelbase - 90 is 90", 110 is 110" and 130 is 130". All 130s are dual cabs supplied with a rear ute tub - can be replaced with a tray. From about 2007 the 110 could also be purchased as a dual cab ute.
The 200tdi and 300tdi are traditional turbo intercooled 4 cylinder diesels made by Landrover. The TD5 is also a Landrover 5 cylinder diesel - not CRD but all electronic and very much up to enhancing. The Puma 2.4 and recently 2,2 diesels are Ford engines and CRD - Tata in India bought Landrover from Ford a little while back but the Indian connection only relates to ownership.
Defenders hold their value pretty well so prices may range from $5k for a 20yo 200tdi to $55K (maybe a bit more) for a current model 130 Puma 2.2.
Psimpson7
Unread post by Psimpson7 » May 25th, 2012, 9:01 pm
Technically the 90 is 92.9" and the 130 is 127" wheelbase :p
Harb
Unread post by Harb » May 25th, 2012, 9:06 pm
which would you say is the best engine....given I will probably do some mods
Psimpson7
Unread post by Psimpson7 » May 25th, 2012, 9:39 pm
Personally I would say the TD5 but that question really is a can of worms.
The TD5 is probably the strongest of all of them, especially the bottom end. None of them like being overheated tho.
I think they are very easy to work on too.
200tdi - economical - parts getting harder to find, especially stuff like heads. no electronics
300tdi - economical, simple, reliable, not very powerful. no electronics
td5 - not quite as economical, more powerful, and can be made a lot more poweful, electronically controlled. very strong engine.
2.4 and 2.2 newest options. Seem ok. Some suffered with vacuum pump failures and so on. 2.2 is getting very complicated with a DPF etc.
Harb
Unread post by Harb » May 25th, 2012, 9:46 pm
Ok , sounds like a TD5 then..... I like good solid foundations to start from....cheers for the info guys :)
Return to “General Land Rover”
