Gear ratio's of 79 series
All Tojo Talk
I have been trying to find the actual gear ratios of the 79 series 1HD fte engine on the web with no luck. Have try searching on this forum again with no luck.
I understand there is a difference in engines between the 79 series 4.2 and the 100 seires engine. Is there a difference in the gearbox ratios as well?
Is the 79 sereis a lower gear ratio like the 105 series 1HZ gearbox?
Cheers Matt H
100 series dual cab landcruiser ute with extended chasis, DTS turbo, 33\'s 4/5 inch lift, 3 x hella 4ooo spoties, air tank & compressor system, hot water shower system, dual battery sytem, snorkel.
Unread postby matt h » September 21st, 2010, 6:59 pm
Re: Gear ratio's of 79 series
Took me to blow a diff and pull it out to find the ratio of my 79 . As much info that told me it was 4.1 there was same amount of info on net telling me it had 4.3s even one diff shop said 4.1 another said his **** toldhim 4.3s
so the petrol 79 series are 4.3
Unread postby Clintfzj79 » September 21st, 2010, 11:47 pm
Thanks for the reply Clintfzj79, but the info I was after was the gear ratios for the 1st,2nd,3rd, 4th and fifth gears inthe gear box.
I am trying to work out if the 79 gearbox ratios in the 4.2 turbo diesel are different to the 100 series 4.2 turbo diesel.
Cheers Matt
Unread postby matt h » September 22nd, 2010, 12:22 am
Have you looked up an old issue of the 4wd action mag?? I think i have the issue lying around when they test drove the HDJ79R and should have the specs. You should be able to find that informantion on the internet too I would hope!
Andy
Unread postby andy086 » September 22nd, 2010, 8:16 pm
matt h wrote:Thanks for the reply Clintfzj79, but the info I was after was the gear ratios for the 1st,2nd,3rd, 4th and fifth gears inthe gear box.
Cheers Matt
my bad
all you need to do to see if they have a different gear ratio in the box is look at the Id tag on the vehicle so maybe stop at some car yards they will either say h150 or h151 sAme box different 1st gear ratio , the turbo v8 utes etc run the h150 my petrol ute runs a h150 im more than sure the td 6 utes and 100s run the h150 aka same ration box
Unread postby Clintfzj79 » September 23rd, 2010, 1:35 am
No dramas Clintfzj79, that is a good idea. I also just found out that a mate of mine's father has one on his farm so I have asked him to find out.
I thought that the 79 sereis might be a little lower geared being more of a workhorse that the 100series turbo diesel.
Cheers Matt H
Unread postby matt h » September 23rd, 2010, 7:11 pm
Hope this is readable - its the 2004 spec sheet for the 78/79series:
Unread postby Phil G » October 4th, 2010, 9:13 pm
Not readable, but looks interesting.
Can just make out some of it.
Do you have a better quality version?
Unread postby SimonW » October 4th, 2010, 10:54 pm
The HDJ79 should have the H150F gearbox. The diff ratio should be 4.1:1
Do the HDJ100s have the H151F?
Below after a quick search on Google and 'H150F ratio'.
http://tlcwiki.com/wiki/H150F_Transmission
Gear Ratios:
1st 4.529:1
2nd 2.464:1
3rd 1.490:1
4th 1:1
5th 0.881:1
Andrew
Unread postby andrewm » October 8th, 2010, 7:50 am
Looking at the brochure as best I can it appears that the H150F trans has a 0.811:1 overdrive ratio? Can anyone confirm this as info is very hard to find?
Unread postby firetruck » October 8th, 2010, 7:16 pm
5th 0.881:1
Andrew
Unread postby andrewm » October 9th, 2010, 7:34 am
I know the info you can find on the web says 0.881, but it does look like 0.811 on the spec sheet posted above.
Unread postby SimonW » October 9th, 2010, 7:54 am
Hi Simon,
You are right - does look like that - and here is another post:
http://www.exploroz.com/Forum/Topic/682 ... eover.aspx
The 4.300 diffs are only found behind the 1Hz motor and the small R151F gearbox.
The 4.100 diffs are found behind the factory TDs with H150F gearbox.
The 4.111 diffs are found in the 60/75/80 series.
FactoryTD 1HD-FTE: HDJ78/79 with H150F gearbox:
1st: 4.529
2nd: 2.464
3rd: 1.490
4th: 1.0
5th: 0.811
Transfer: 2.488
Diffs: 4.100
N/A Diesel 1Hz: HZJ78/79/105 with R151F gearbox:
1st: 4.313
2nd: 2.330
3rd: 1.436
4th: 1.0
5th: 0.838
Transfer: 2.295
Diff 4.300
60/61/75 series with H55F gearbox:
1st: 4.843
2nd: 2.618
3rd: 1.516
4th: 1.000
5th: 0.845
Transfer: 1.963
Diffs: 4.111
80series. 1Hz had H150F box with 2.488 transfer and 4.111 diffs
80series 1HD-T and 1FZ-FE had H151F box, 2.488 transfer and 4.111 diffs:
1st 4.081
2nd 2.294
3rd 1.49
4th 1.0
5th 0.881
Unread postby andrewm » October 9th, 2010, 6:26 pm
Sorry guys,
Just rescanned the relevant bit. Hope its more readable. But I think you guys have picked up a typo - the overdrive should be 0.881 - I have confirmed this on another printout I have from 2004 and also this site:
http://www.pressroom.com.au/newpressroom/toyota/presskits/07LC70/21.xls
Unread postby Phil G » October 10th, 2010, 8:22 pm
Was hoping the later H150F had a taller overdrive like the brochure suggests. Would be a straight swap for the H151F in my 80 which has a useless 0.881 overdrive. May as well call it a 4 speed..... Oh well, more research on the H260.....
Unread postby firetruck » October 10th, 2010, 8:50 pm
Next
Return to General Toyota
Who is online
  • Follow US
4wd Action Club
Member
Login
Join the Club
