80 series air-con pulley bearing
All Tojo Talk
woolgoolgaoffroad
Unread post by woolgoolgaoffroad » October 7th, 2007, 6:40 pm
hey guys,
the bearing behind the pulley on the air con unit, on my 80 series diesel is howling and growling. I know it is this as i pulled the belt off and it stooped, and the pulley is hard to turn.
My question it, if i undo the 10mm bolt on the front of the air con unit, will the pulley and bearing come straight off, or will i need to take off the whole unit,??? ( which might mean getting it re-gassed ).
roscoFJ73
Unread post by roscoFJ73 » October 7th, 2007, 8:32 pm
woolgoolgaoffroad wrote:hey guys,
The pulley will come off if you undo that bolt.No regassing etc Toyota will only sell you a complete clutch for about $200. I found an aircon shop that replaces the bearing with an aftermarket type. You could do it yourself if you remove the bearing and take it to a bearing distributor to size up the bearing.
woolgoolgaoffroad
Unread post by woolgoolgaoffroad » October 7th, 2007, 9:01 pm
roscoFJ73 wrote:The pulley will come off if you undo that bolt.No regassing etc Toyota will only sell you a complete clutch for about $200. I found an aircon shop that replaces the bearing with an aftermarket type. You could do it yourself if you remove the bearing and take it to a bearing distributor to size up the bearing.
thanks, have a mate that has a bearing shop,soi will go that way......
had to happen at the start of summer, grrrrr
thanks again
roscoFJ73
Unread post by roscoFJ73 » October 8th, 2007, 11:42 am
woolgoolgaoffroad wrote:thanks, have a mate that has a bearing shop,soi will go that way......
thanks again
Better than in the middle of summer;)
HDJ105
Unread post by HDJ105 » October 8th, 2007, 2:05 pm
thanks again
If it's the original genuine ND compressor, ask your mate for a Nachi 30BGS10DST or equivalent. ;)
Greg G.
2000 HDJ105 ~ 1HD-FT I/C TD
FourXfouR
Unread post by FourXfouR » October 8th, 2007, 5:23 pm
Once you undo the 10mm nut you will have to prise the front plate off. Once you have done that there is a circlip which needs to be removed before the pulley will come off. The pulley generally needs to be removed with a 3 legged puller. If you decide to use a pair of screwdrivers ( this does work ) just be careful not to damage the clutch coil behind the pulley.
The bearing is a press fit in the pulley itself and has nothing to do with the clutch. Either smash it out and tap a new one in or have a shop do it for you.
Are you sure its only the pulley bearing? Take the belt off and spin the pulley. Then spin the front plate of the compressor and make sure it turns smoothly
4" lift, 33" Bighorns, Rear Air Locker, Winch, Rock Sliders
woolgoolgaoffroad
Unread post by woolgoolgaoffroad » October 8th, 2007, 6:30 pm
FourXfouR wrote:Once you undo the 10mm nut you will have to prise the front plate off. Once you have done that there is a circlip which needs to be removed before the pulley will come off. The pulley generally needs to be removed with a 3 legged puller. If you decide to use a pair of screwdrivers ( this does work ) just be careful not to damage the clutch coil behind the pulley.
yeah i did take the belt off, noise stopped straight away. and as for spinning the pulley, i cant, its bloody so notchy, so i will put money on that this is the problem.
thank you for your reply
kev
and thanks 105 for the part numbers
FourXfouR
Unread post by FourXfouR » October 8th, 2007, 7:14 pm
ah sweet, no worries then
jimbo jones
Unread post by jimbo jones » October 8th, 2007, 10:48 pm
he is right on the money make shoure you get that c clip off not a really hard job
http://illawarrasuzuki4wdclub.webs.com/
FourXfouR
Unread post by FourXfouR » October 9th, 2007, 7:09 am
Also I forgot to mention. Once you have it all apart check the surface that the inside of the bearing sits over ( alloy nose cone on the compressor ) if its damaged in any way then you have a bigger drama on your hands
woolgoolgaoffroad
Unread post by woolgoolgaoffroad » October 9th, 2007, 7:19 am
FourXfouR wrote:Also I forgot to mention. Once you have it all apart check the surface that the inside of the bearing sits over ( alloy nose cone on the compressor ) if its damaged in any way then you have a bigger drama on your hands
good on ya, now i am getting scared !!!!!
lol,thanks
roscoFJ73
Unread post by roscoFJ73 » October 9th, 2007, 2:26 pm
I forgot the cir clip:o It can be easy to damage the lip trying to get the clip over the edge of it.
FourXfouR
Unread post by FourXfouR » October 9th, 2007, 7:14 pm
woolgoolgaoffroad wrote:good on ya, now i am getting scared !!!!!
lol,thanks
haha sorry mate,
But....I thought I would let ya know, saves ya putting it all back together and having it happen all over again!
woolgoolgaoffroad
Unread post by woolgoolgaoffroad » November 27th, 2007, 5:13 pm
well i took everyones advice, seek some help from our local air con place and he gave me the same advice as you guys ( not that i ever doubted it !!! )........................ took it all apart, one thing he did tell me was put a live wire to the plug on top of the air con, and this will lock the plate to the pulley-makes it easier to crack the 10mm nut on top. Easy.
Next i took the very locked bearing to a mate, pressed it out, got a new one from next door ( $27.40 ) new one pressed in ( free ) and now i am one cool cucumber.
So thanks to every one for their help.
FourXfouR
Unread post by FourXfouR » November 27th, 2007, 6:04 pm
Glad to hear she is all sweet mate, good little tip using the clutch pack to crack the bolt, I generally use air tools at work so have never had a drama
Return to “General Toyota”
