Hilux and 4Runner Info
All Tojo Talk
MrHilux
Unread post by MrHilux » June 21st, 2009, 9:57 pm
The conversion was done on mine, before I owned it. Was power steering optional in the LN106?
A1 Mech
Unread post by A1 Mech » June 22nd, 2009, 9:53 pm
Yes pretty sure AC was a standard item and P/S an option :crazy:
A P/S fan clutch and radiator are also neccessary as the originals lower hose is in the wrong position and the fan clutch will not clear the new pulleys.
[align=center][size=134][color=red][b][u]Gen2 turbo 4Runner[/u][/b][/color][/size][/align]
[align=center]3" SAS TG kits FnR, FnR ARB's, R150F, 23spline duals with 4.7's, 30s Longs, 33" MTZs road, 36x13.5 Iroks play, fullbarwork....etc.[/align]
[al
MrHilux
Unread post by MrHilux » June 22nd, 2009, 10:10 pm
A friend of mine has strong arm steering in his 87 triton. Can a P/S conversion be done easily on his?
A1 Mech
Unread post by A1 Mech » June 23rd, 2009, 8:33 pm
Not sure mate I imagine that if there is a model of his vehicle/engine with P/S from the factory then all the gear associated could be sourced and fitted to his just like we did with the LN106 lux. Google could be you best friend with this.
[al
MrHilux
Unread post by MrHilux » June 23rd, 2009, 9:15 pm
A1 Mech wrote:Not sure mate I imagine that if there is a model of his vehicle/engine with P/S from the factory then all the gear associated could be sourced and fitted to his just like we did with the LN106 lux. Google could be you best friend with this.
Thanks, might look into it now. Just depends on what mods are more important for him on his bitsamissin triton. :) All 4WD's should have P/Steering as standard!:thumb:
raytriplej
hilux newby question
Unread post by raytriplej » September 5th, 2009, 10:50 pm
deleted
A1 Mech
Unread post by A1 Mech » September 6th, 2009, 8:51 am
Its called the torque rod and it stops axle wrap under braking and accelerating. They do occassionally crack at either end if the lux has seen a long life of torture or hard roads, having taller more flexible springs without upgrading to an adjustable torque rod will c extra stress put on it also.
[al
raytriplej
Unread post by raytriplej » September 10th, 2009, 12:33 am
deleted
raytriplej
Unread post by raytriplej » September 10th, 2009, 12:03 pm
deleted
A1 Mech
Unread post by A1 Mech » September 10th, 2009, 4:49 pm
Yes the diffs are interchangeable front to rear, as far as gear stick boots go your best bet wud be to try the wreckers for a good condition one that fits, Or u could try an auto store or the net for a universal rubber bellow type.
[al
raytriplej
Unread post by raytriplej » September 14th, 2009, 8:54 am
deleted
matt_ratt
Unread post by matt_ratt » September 26th, 2009, 10:49 am
none of these links on this page are working?????
raytriplej
Unread post by raytriplej » November 2nd, 2009, 10:59 pm
deleted
A1 Mech
Unread post by A1 Mech » November 3rd, 2009, 7:45 am
No not neatly or easily as the body dimensions are different. With a bit of panel beating or modification they may tho.
[al
raytriplej
Unread post by raytriplej » November 3rd, 2009, 11:01 am
deleted
Return to “General Toyota”
