GQ/GU PATROL Thread BIBLE
For the Nissan nuts
Patrolling Paddy
part numbers for speedo correction
Unread post by Patrolling Paddy » August 24th, 2007, 1:25 pm
Posting on behalf of Pete Polly
Hi PP, thought this might come in handy for the tech info thread, so those with larger tyres can get the correct speedo reading.
Tyre size (in) / No. Teeth / Nissan Part Number
3.9 Diff Ratios:
31 / 16 / 31G16
33 / 15 / 31G15
35 / 14 / 31G14
37 / 13 / 31G13
4.1 Diff Ratios:
31 / 17 / 31G17
33 / 16 / 31G16
35 / 15 / 31G15
37 / 14 / 31G14
4.375 Diff Ratios:
31 / 18 / 31G18
33 / 17 / 31G17
35 / 16 / 31G16
37 / 15 / 31G15
4.625 Diff Ratios:
31 / 19 / 31G19
33 / 18 / 31G18
35 / 17 / 31G17
37 / 16 / 31G16
GQ SWB, TD42 naturally asthmatic, home made bar, 2" body lift, 33" Cooper STTs and dints
Quote:
Originally Posted byPatrolling Paddy
That is awesome, thanks for that.
What are your sources and or how did you work it out and I can add that too.
PP
from outers
__________________
You can only work with the tool God gave you.:D
Patrolling Paddy
Unread post by Patrolling Paddy » August 28th, 2007, 12:11 am
A new section on steering has been added to the BIBLE.
Cheers Vektahaus for the suggestion
PP
Patrolling Paddy
Unread post by Patrolling Paddy » December 1st, 2007, 7:00 am
This has been quiet for a while now.
Are people using this Bible?
Are there any new inclusions that you would like added?
I will scout the threads again soon and see what I can come up with but if you have anything please let me know and I will add it.
PP
bshslt
Unread post by bshslt » December 2nd, 2007, 7:46 am
Hi PP, maybe intercoolers what people have been using? Cheers Cam
Wirregar
Something to consider adding
Unread post by Wirregar » February 7th, 2008, 11:34 pm
Patrolling Paddy wrote:This has been quiet for a while now.
PP
How about adding some sections about Diesel/Gas mods or Chips?
Patrolling Paddy
Unread post by Patrolling Paddy » February 10th, 2008, 4:15 am
Wirregar wrote:How about adding some sections about Diesel/Gas mods or Chips?
I will try to add something with direct info on GQ/GU Patrol, some of the discussions have been general dieselgas but I will have a look and see what I come up with.
Are you wanting maybe what brands to use or are you looking for perfomance or economy info or all of the above?
I don't recall off the top of my head any Chip info for the Patrols but if you see something send me the link and I can add it in.
PP
jjsgu
Unread post by jjsgu » February 10th, 2008, 3:55 pm
all help welcome guys. Having not long purchased a gu patrol 98 model has anyone got any ideas to improve fuel economy. It is by the way on petrol/gas. We have just had extractors fitted and they have made a lot of difference to the performance of the vehicle. Don't know yet about the economy side of it though. We are having a snorkly fitted soon as well.
Patrolling Paddy
Unread post by Patrolling Paddy » February 10th, 2008, 8:23 pm
jjsgu
I have not yet found the information you are chasing and therefore not yet added it to the bible, I will keep scouting and will update from time to time.
The bible is meant to be the 1 stop shop for GQ/GU Patrols and although the information may be on the forum somewhere the bible is not intended to be where we ask the question but where we may find the answer. If you post your question in the Nissan tech as it's own thread (after doing a search first) you will most probably find someone with the answers you seek.
If you do find the answers in a 4WD Action thread let me know here and I can add it in.
PP
kjparker
Unread post by kjparker » February 21st, 2008, 1:58 pm
HI,
It's probably just me, but is anybody else having problems with the links? I need to copy and paste them, and remove part of the link for it to work!
Patrolling Paddy
Unread post by Patrolling Paddy » February 24th, 2008, 10:45 am
I must admit I haven't checked them for a while but I cannot open them either I will see if the Mods or Admin can help.
Cheers for the heads up
PP
Maineiac
Unread post by Maineiac » February 26th, 2008, 2:00 pm
The only way I've been able to view them is the same as kj's. Copy them then delete everything before the 2nd HTTP://
2000 GU 4.2TD .
bullet4x4
Unread post by bullet4x4 » February 18th, 2009, 10:47 am
not sure if its me but every link i click on just takes me to the main forum page????
Patrolling Paddy
Unread post by Patrolling Paddy » March 5th, 2009, 1:50 pm
bullet4x4 wrote:not sure if its me but every link i click on just takes me to the main forum page????
It has been an issue that so far has not been able to be fixed.
Try and copy the link into the address bar and it should work.
PP
sazzle
Unread post by sazzle » February 2nd, 2010, 4:21 pm
could we possibly coalate a section on he good old radaitor troubles/ repairs/ tricks to keep our trucks cool. i no its a common problem and i know there are plenty of threads in here but it would be so easy to be able to come straight here
matt_ratt
Re: GQ/GU PATROL Thread BIBLE
Unread post by matt_ratt » April 6th, 2011, 9:45 pm
the links on this page are still not working, well i couldn't get them too. even tried copy paste. :)
Return to “General Nissan”
