GQ/GU PATROL Thread BIBLE
For the Nissan nuts
Patrolling Paddy
Unread post by Patrolling Paddy » July 29th, 2007, 1:11 pm
Contained in these links are projects and answered questions about GQ/GU PATROLS
Please PM any proposed additions or inclusions to Patrolling Paddy or Peter @ Aawen4x4
NOTE: If you have problems getting these links to work, try holding the Ctrl Key down while you click the left mouse button on the selected link. Otherwise, Copy & Paste the link into the Address bar before selecting GO. IF your browser duplicates the address or adds duplicate http:// details prior to the http:// immidiately prior to the address, delete that prior info and re-try.
ENGINE DIESEL
http://www.4wdmonthly.com.au/forum/f43/ ... a-v8-35730
http://www.4wdmonthly.com.au/forum/f43/ ... dex2.html]
·http://www.4wdmonthly.com.au/forum/f43/ ... -gq-36481/
·http://www.4wdmonthly.com.au/forum/f43/ ... wer-36282/
·http://www.4wdmonthly.com.au/forum/f43/ ... ter-36186/
·TD42 engine missfire - Australian 4WD Action Online Forums
ENGINE PETROL
·http://www.4wdmonthly.com.au/forum/f43/ ... ark-36582/
·http://www.4wdmonthly.com.au/forum/f43/ ... rol-36887/
·Air tight intake for gas carbied GQ - Australian 4WD Action Online Forums
TURBO
·http://www.4wdmonthly.com.au/forum/f43/ ... d42-41085/
GEARBOX/TRANSFER
·http://www.4wdmonthly.com.au/forum/f43/ ... old-36803/
·GQ Auto?? strong enough? - Australian 4WD Action Online Forums
* Gearbox Issue - Australian 4WD Action Online Forums
DIFF
·http://www.4wdmonthly.com.au/forum/f43/ ... cks-35713/
·Re-inforcing/stengthening GQ/GU diff housings - Australian 4WD Action Online Forums
BRAKES & HUBS
·Nissan Hub bearings (front wheel bearing GQ) - Australian 4WD Action Online Forums
CV’s
·http://www.4wdmonthly.com.au/forum/f43/ ... -cv-37011/
·Gq Patrol Cv's - Australian 4WD Action Online Forums
SUSPENSION
·http://www.4wdmonthly.com.au/forum/f43/ ... ues-37005/
·http://www.4wdmonthly.com.au/forum/f43/gq-lift-36761/
·http://www.4wdmonthly.com.au/forum/f43/ ... cer-35239/
STEERING
·http://www.4wdmonthly.com.au/forum/f43/ ... ion-38469/
SERVICING
·http://www.4wdmonthly.com.au/forum/f43/ ... ons-36950/
BODY WORK
·How to replace rear GQ sliding windows - Australian 4WD Action Online Forums
·Replacing GU Body/chassis rubbers - Australian 4WD Action Online Forums
·http://www.4wdmonthly.com.au/forum/f43/ ... -gq-35686/
·GQ Quater chop/guard cut - Australian 4WD Action Online Forums
BARWORK
RECOVERY POINTS
·http://www.4wdmonthly.com.au/forum/f43/ ... nts-32844/
INTERIOR/CABIN
·http://www.4wdmonthly.com.au/forum/f43/ ... -gq-35695/
·http://www.4wdmonthly.com.au/forum/f43/consoles-37063/
ELECTRICAL
·http://www.4wdmonthly.com.au/forum/f43/ ... g-q-36994/
·Intermittent front wiper problem GQ - Australian 4WD Action Online Forums
·Aftermarket cruise control (GU 4.2D) - Australian 4WD Action Online Forums
·GQ Altenator Q? - Australian 4WD Action Online Forums
FUEL ECONOMY
WHEELS
·patrol V crusier rim offset ? - Australian 4WD Action Online Forums
MISC. Not sure where to put these.
·patrol 4.2 diesel - Australian 4WD Action Online Forums
This is just the start as it is a big job.
Please feel free to add links you would like added and I will add them if they are relevant (build-up, tech etc.. as long as it is relevant to GQ/GU) and at this stage the Moderators are happy to make this a STICKY.
PP
NOTE: If you have problems getting these links to work, try holding the Ctrl Key down while you click the left mouse button on the selected link. Otherwise, Copy & Paste the link into the Address bar before selecting GO. IF your browser duplicates the address or adds duplicate http:// details prior to the http:// immidiately prior to the address, delete that prior info and re-try. :computer:
Unread post by Peter Aawen » July 29th, 2007, 2:49 pm
Great Job PP, it is STICKY!
Patrolling Paddy
Unread post by Patrolling Paddy » July 29th, 2007, 4:15 pm
Cheers Peter
As said this is only a start and I encourage feedback and input from other members so we (the members) end up with something that can be a great resource for all.
PP
Unread post by Peter Aawen » July 29th, 2007, 7:19 pm
Bit of Housekeeping PP.
Can you edit that 'Bible' Post? I expect that you should be able to own posts, so you should be able to use the edit facility to fine tune that first post as/when things come up or are improved upon.
I can keep the thread clean & to the point, so for now, I'll leave it as is right now; just a sticky and not locked, and if others have things to add, they can:
[INDENT]post them in here, or
PM them to you (or me) and
they can get added to the 'Bible'!
[/INDENT]If they are an approprite post to have their own status, they can stay in the thread.
But, if they are not up to the high standards already set, they may be modified or deleted.
I can manage that side of things, or any of the Administrators & a few of the other Moderators, but ask them nicely please, they'll be doing it as a favour!
Anything else we shpould think about right now?
Patrolling Paddy
Unread post by Patrolling Paddy » July 29th, 2007, 10:18 pm
I will keep an eye on this one, seeing as I suggested it, and add links to the original as they happen.
I haven't finished but as you can appreciate it will take some time to go through the forum and get the bits we need.
PP
Pil
Unread post by Pil » July 30th, 2007, 2:22 pm
Great thread idea Patrolling Paddy, I'm adding it to my subscribed threads for sure. I have no doubt it will be very popular.
Here's a thread I found that could be added to the WHEELS section: http://www.4wdmonthly.com.au/forum/f10/ ... set-28207/
Spudda
Unread post by Spudda » August 1st, 2007, 10:15 pm
Could you include a section on Home Made Drawers or designs.
Not sure if anyone has shared there pics or not.
Just an idea as i'm in the process of desinging a set
Andy
Unread post by Peter Aawen » August 1st, 2007, 10:54 pm
Got any links? It will probly end up under Interior/Cabin but we'll see. PM any links that you know of to Patrolling Paddy or to me, Peter @ Aawen4x4
Patrolling Paddy
Unread post by Patrolling Paddy » August 1st, 2007, 11:02 pm
Spudda wrote:Could you include a section on Home Made Drawers or designs.
Andy
Andy, I am more than happy to put in what the people would like.
Having said that I am one person and it will take me some time to collate all sorts of links (I will only be concentrating on this site).
If you have seen a thread that you feel should be included then PM myself or Peter and I will endevour to get it added to the BIBLE for all to use.
Great idea though.
PP
Pil
Unread post by Pil » August 2nd, 2007, 12:35 pm
Andy
Here are a few links for Cargo Drawer Construction. I haven't read them all, but the ones I've read look pretty good. I'm gonna build a set as soon as funds allow, probably using 'DT's Home Made Roller Drawers' as a base.
http://www.4wdmonthly.com.au/forum/f22/ ... ers-35635/
'DT'S Home Made Roller (DT'S Home Made Roller Drawers.)Drawers'
'Rear draw system'
'Fridge Slide/Drawers for 2002 Hilux'
Drawer system for MQ swb on a buget'
http://www.4wdmonthly.com.au/forum/s...hlight=drawers (Rear draw system)
http://www.4wdmonthly.com.au/forum/f10/ ... GO+DRAWERS
Pil
Patrolling Paddy
Unread post by Patrolling Paddy » August 2nd, 2007, 4:34 pm
Pil wrote:Here are a few links for Cargo Drawer Construction. I haven't read them all, but the ones I've read look pretty good. I'm gonna build a set as soon as funds allow, probably using 'DT's Home Made Roller Drawers' as a base.
Pil
Pil, I greatly appreciate the enthusiasm and effort to put those links up for us, however although they are all very informative, they are also for Toyota's and a MQ.
This BIBLE is directed at GQ/GU so at this stage I don't think they will be included in the BIBLE but perhaps if you added these to the General 4wd FAQ's or PM'd one of the moderators about starting your own bible in the general 4wd or for another model??
PP
You can only work with the tool God gave you.:D
Patrolling Paddy
Unread post by Patrolling Paddy » August 2nd, 2007, 4:40 pm
Consider it added Pil, this has some info that can be handy if putting aftermarket wheels on or setting up for some good mods.
PP
Pil
Unread post by Pil » August 2nd, 2007, 4:47 pm
Yeah, fair enough. I noticed they weren't specific to GQ/GU's, but they also dont have any specific measurements, so I figured that poeple could get the general idea and take it from there. But you're right, they probably dont belong on a dedicated GQ/GU thread.
aussie bugs
Unread post by aussie bugs » August 4th, 2007, 12:30 pm
Hi guys I have a 99 GU and my keyless only works when it whats to does anybody have the same problem with theys and if so have you been able to fix it
your 4WD bud Aussie bugs
Patrolling Paddy
Unread post by Patrolling Paddy » August 5th, 2007, 3:53 am
I have been through the Nissan Tech section and the GQ/GU BIBLE is up to date from that as of 5/8/07.
Please feel free to add to this as the more input I can get the better the BIBLE will be.
My next mission is to go through the other sections and find relevant info to add to the GQ/GU BIBLE.
PP
Return to “General Nissan”
