Do GQ/GU petrol tanks have swirl pots or baffles?
For the Nissan nuts
jgrov2
Unread post by jgrov2 » August 5th, 2014, 9:14 pm
Hello
Id like to know if the large rear tanks on the back of the gq/gus have swirl pots or internal baffles. Reason I ask is because im looking at throwing one in my ute for a conversion and would like to avoid using a surge tank if I could. Ideally it would sit where the spare wheel currently sits under the tray. Im thinking maybe the EFI tanks have something to constantly feed the intank pump. do the diesel tanks have anything?
cheers lads
4.3L V8 LN106 Hilux Thread - viewtopic.php?f=189&t=159892
WD21
Re: Do GQ/GU petrol tanks have swirl pots or baffles?
Unread post by WD21 » August 6th, 2014, 5:50 pm
Just had a look in a GQ 95L tank.
They appear to have baffles, so you should be fine. :thumb:
New Terrano build!
jgrov2
Unread post by jgrov2 » August 6th, 2014, 7:13 pm
sweet thanks man
Return to “General Nissan”
