Driving lights stolen off my collie
Stolen vehicles and parts, help us track them down!
JJLTZ
Unread post by JJLTZ » June 27th, 2014, 7:46 am
Anyone know what would be the best way to secure a set spotlights to my nudge bar?
Some c(_)nt stolen mine last night parked outside my mates place.
Now I have empty brackets on my car and its pissing me off whenever I walk to my car....
mattm
Re: Driving lights stolen off my collie
Unread post by mattm » June 27th, 2014, 7:58 am
Araldite the nuts/bolts, will be a pain in the arse if you ever want to get them off your self but as you'll need to heat them to melt the araldite but guarentee they won't get stolen again
chris_stoffa
Unread post by chris_stoffa » June 27th, 2014, 8:46 am
Fine drill hole and a tight fitting steel split pin through the nut
03 Bravo 2.5TD DCab
MasterInnovator
Unread post by MasterInnovator » June 27th, 2014, 8:55 am
Hammer the ends of the bolts if you can, it mushrooms the bolt ends, no one will be able to undo the nut at all-if not that then it would be bloody hard...I have done that
Les - PK Ranger
Unread post by Les - PK Ranger » June 27th, 2014, 11:54 am
Good thread here . . . viewtopic.php?f=7&t=133986&p=1624684&hi ... e#p1624684
The stainless rivets are reasonably easy to drill out if you ever want to remove them, but not so easy to deal with at night or with a cordless drill as it irks these lowlifes to make any noise, or take longer than a few minutes.
Scantek
Unread post by Scantek » July 19th, 2014, 1:11 pm
I have drilled a hole through the nut and bolt, knocked a roll pin through and filed it off so it cant be detected easily.
Never had an issue
Russ
Return to “Stolen”
