middy strength-bj73
sprungupcruiser
Re: middy strength-bj73
Unread post by sprungupcruiser » November 13th, 2012, 4:00 am
Cheers Nate.
Toyholden
Unread post by Toyholden » November 13th, 2012, 6:30 pm
Fully Sick Rig !!!!
Just read your whole build... Insane :twisted:
Tops idea with the front anti-wrap bar... some awesome enginuety... V8 rumble... :thumb:
I so want to build a comp truck after reading though this thread... so many good ideas have come from this build :D
Now im doing head miles... how to chop chop a SURF & make it different... I hate copycating... But first i nead to find a buyer for my left kidney :lol:
"DUCK"
sprungupcruiser
Unread post by sprungupcruiser » November 13th, 2012, 7:33 pm
Hahaha thanks mate. I don't think I have copied anyone's car but I have certainly used other cars for inspiration.
sprungupcruiser
Unread post by sprungupcruiser » May 18th, 2013, 7:20 pm
Here's a bit of an update/complete rebuild/changing everything. While I never had too many driveline breakages with my current setup I have the desire to do some rock racing/tuff truck in the future and I'd like to build it and not have to worry about running what ever tires I want. So here's a bit of what is planned for the old girl
-LS1, sitting in the shed all ready
-TH400, getting built at the moment
-Atlas 4 speed (that's the plan at the moment)
-4 link front and rear with 16" coil overs and provisions in the mounts for triple bypass shocks
-Dana 60 front and Dana 70B rear, I have the D70b in the yard already and I'm in the process of getting the dana 60 from the states
- Re build the cage to meet Aust4/CAMs specifications
-Tube the rear
-Tube guards
-Rear mount radiator
-Sheet metal dash
-Full hydro steer
Here's some photos of the blank canvas and the parts I've got.
Driveline coming out
Dana 70B
LS1 out of a later VY SS
A photo from the Lowmead 3 car comp report in 4wd action
So lots of work ahead but it will be worth it in the long run with more time driving/competing and less time fixing/replacing parts. Stay tuned.
sprungupcruiser
Unread post by sprungupcruiser » May 26th, 2013, 9:18 pm
Kicked some goals this week have repaired most of the rust in the cab and more less got the roll cage done. To fix the rust I used a bit of a dodgey method but it looks good and I just cant justify the $1300 replacement panel from Toyota. The method involved expander foam, body filler, then a couple of layers of fiber glass then finished up with more body filler. It came up well and you'd hardly know any different, if it last a few years I'll call it a win.
Step 1. Load that bastard up with foam
Step 2,3 and 4. Shape foam with saber saw, bog to roughly the right shape but a few mil undersize, lay fiber glass over the top of that sucker.
Step 5. use bog to get it to the final shape required
step 6. Paint it. Good as new, see nothing suss going on here.
sprungupcruiser
Unread post by sprungupcruiser » May 26th, 2013, 9:20 pm
The roll cage is a little more text book...
this is about as creative as I get with photography, the notching station.
Yush
Unread post by Yush » May 27th, 2013, 2:02 pm
Wow. That job you did wih the fibreglass, just wow.
If you'd asked me what was wrong/different with the aftershot without seeing your instructions, I'd still be sitting here scratching my arse with a confused look on my face.
sprungupcruiser
Unread post by sprungupcruiser » May 27th, 2013, 2:46 pm
Thanks bud, I certainly wouldn't recommend it if I was a panel beater trying to do a job for someone but for a car that could write the cab off in the first trip, it will do the job.
sprungupcruiser
Unread post by sprungupcruiser » May 28th, 2013, 9:06 pm
Got the cage 90% welded and added the side impact bars and the A pillar stays. Most of it was TIG welded but I ran out of argon so I had to do the A pillar with the MIG. Not the prettiest Tig welds going but they're not too bad.
The bit I MIG welded.
sprungupcruiser
Unread post by sprungupcruiser » June 10th, 2013, 4:30 pm
Got little bit done this week, Added a second tube in the dash to take the sheet metal and to pick up the center console tubes. I'm think that the seat mounts will come off this tube somehow.
My suspension seats turned up, I might have to get a 3" taller seat for my side I think.
This is my front axle, currently sitting at my freight forwarder in Battle Ground in washington.
sprungupcruiser
Unread post by sprungupcruiser » July 7th, 2013, 8:01 pm
Updates...
Added some more tubes to the cage for seat mounts, the rest of the mounts will be laser cut plate.
Second B pillar tube, will be infilled with some ally sheet.
I wanted to make the the front approach angle 90* but if I moved the axle forward I would have to run the ride height higher than I wanted to get the 5-6" of up travel I want, so instead of re profilling the chassis I moved the cab back about 140mm.
New rear body mount, would have been too hard to save the original one.
sprungupcruiser
Unread post by sprungupcruiser » July 14th, 2013, 5:43 pm
So after spending all Sunday last weekend shifting the body on the chassis, I had to move it all back yesterday to meet Tuff Truck rules. Every other comp allows it except the one I would have thought would have allowed, never mind at least I got to use the body mounts I made last week.
I also got the seat mounts installed
sprungupcruiser
Unread post by sprungupcruiser » July 14th, 2013, 5:46 pm
And I also got the adjustable ''Jesus" bar made and fitted up
sprungupcruiser
Unread post by sprungupcruiser » August 20th, 2013, 7:04 pm
Making some head way, work keeps getting in the way of my hobby unfortunately. This is some progress from over the last month.
Steering wheel mount, uses some of the original bracket. I just happened to jag the the position of it so that the original column bolts up.
Got some of the ally panels made and mounted, dimples.....
Got the engine mocked up and the mounts stitched into place. Thanks for watching!
sprungupcruiser
Unread post by sprungupcruiser » August 24th, 2013, 4:03 pm
I got my sliders done this weekend so far, I think I'm going to be hungover tomorrow so not sure I'll achieve much more this weekend.
Axle is sitting in my mates workshop in Brissy, just got to get it up here, gets some wheels and tyres and then I can mock up axles under the car and start looking at the suspension.
