1991 toyota 4 runner vzn130r
ltd_v8
Re: 1991 toyota 4 runner vzn130r
Unread post by ltd_v8 » June 11th, 2017, 8:32 am
so update
well sadly the 4runner got written off due to water in the engine from a creek i tried to cross where the front end just sank : so i bought myself a 1999 toyota prado dual fuel auto and so far i have put snorkel on it and my awning, i still need to put my other stuff from the 4runner in it.
i payed $2200 for it, body is rough but straight, it did have a few problems like lpg back fire under load so i replaced coil packs, and a new intake hose. i have not hooked the lpg back up only because im putting the main tank back in for touring. i have a high idle so i cleaned the throttle body out, i have a feeling its the iac. still idles around 1800rpm. everything works as it should, even the aircon. i replaced the back shocks, what a prick of a job, and im about to do the rear pan hard rod bushes because there is nothing left of the old bushes and it knocks and sways like a bitch!
Unread post by BigDutchy » June 11th, 2017, 12:43 pm
This will be a great truck by the time you are finished with it. A real shame of the 4runner mate.
ltd_v8
Unread post by ltd_v8 » July 8th, 2017, 8:20 am
a bit of a update i started to get really bad wandering over the road and my first though was yep inner racks are stuffed so i ordered the 555 inner racks and tire rods and lower ball joints all 555 stuff cause the previous owner did state he did replace the inner racks well the inner racks weren't the problem when the previous owner got a wheel alignment done who ever did it forgot to tighten the lock nut up so because the outer tire rods where stuffed i replaced those but have spare inner racks only because i will see how it goes in a week or so if i should change it or not
ltd_v8
Unread post by ltd_v8 » July 26th, 2017, 8:24 am
so update i finally got a new airbox at a good price of $20 i was still experiencing wandering so i bought 2month old tough dog suspension 2inch lift with king springs still the same only to discover that the lower control arm bushes are flogged out really bad and that was my problem so i got the new bushes and yet to install them yet so thats getting all done this weekend and then same with upper control arm bushes and new steering rack bushes all whiteline stuff
ltd_v8
Unread post by ltd_v8 » December 4th, 2017, 12:24 pm
so a bit of a update photobucket sucks now all new bushes are in also done a lot more since then as well I also picked up another Prado for $500 blown engine good body but I'm stripping it
before
after
ltd_v8
Unread post by ltd_v8 » December 10th, 2017, 6:34 pm
so update time my duel battery setup is complete all i need is a deep cycle battery also my roof light is on next month is my new bull bar lpg is running good but it is still coming out when i plan for the cape york trip in 2 years time
ltd_v8
Unread post by ltd_v8 » January 15th, 2018, 7:29 am
so update time i ended up getting a 90l main fuel tank complete for $50 i also purchased a single titan draw and im now hooked up for solar the lpg is finally removed i will take full pic of the inside and out later
ltd_v8
Unread post by ltd_v8 » January 16th, 2018, 2:51 pm
here is the pic
