My Jeep mod's
Clarkey16
My Jeep mod's
Unread post by Clarkey16 » September 11th, 2014, 10:47 pm
This is my 2006 Grand Cherokee, It has a 2" lift & 265/70/17" tyres.
There are no engine mods or chips, in stock form it has 160kw & 510nm torque.
It has factory fitted Eaton electronic limited slip diff's that can fully lock & are controlled by the traction control system.
Today I fitted my new larger capacity B&M transmission pan to my 06 Grand, should help keep the temps down ;)
The pan fits the NAG1 G/box in diesel grand 2004 to 2011 & JK Wranglers with the tiptronic auto shift.
Yes I did! Built with spanners not chop sticks!
Clarkey16
Transmission Temp gauge & volt gauge
Unread post by Clarkey16 » September 14th, 2014, 7:30 pm
Gauges to match
Clarkey16
Brake upgrade
Unread post by Clarkey16 » October 7th, 2014, 1:29 pm
Picked up my new DBA XS front rotors at 12:15, fitted by 13:15 :D
The rims are off a Commander changing the offset to 43.8 mm from the original 51.4 mm
Tyres are 265/70/17 Big Horn's
Last edited by Clarkey16 on October 25th, 2014, 12:19 am, edited 2 times in total.
Clarkey16
Airflow snorkel
Unread post by Clarkey16 » October 8th, 2014, 3:29 pm
Airflow snorkel
The template was fairly close, only filed 2 of the 10mm holes to provide adequate clearance.
I used a 95mm hole saw for the intake hole (5mm bigger then recommended) and fitted a rubber seal from an oven door around the hole making it a snug fit.
The only concern is the flex hose that connects the snorkel to the air box is in contact with the inner plastic guard,
I was worried it would rub through but I couldn't see any other way to rout the hose through, I ended up using a hot air gun to re-shape the inner guard to improve clearance.
I will see if the snorkel head grows on me, if not I will replace it with this
Clarkey16
Saguaro Bar & Runva Winch
Unread post by Clarkey16 » October 8th, 2014, 3:31 pm
Aspen Creek Saguaro Bar & Runva 11XP Winch
Have since moved the control box to behind the grill.
Clarkey16
FleBay Lights
Unread post by Clarkey16 » October 23rd, 2014, 8:45 am
Can't justify $1000 on lights at the moment (lightforce LED 180's) so I got a set of eBay cheapies.
90 watts each, $250 pair
Look like a copy of Great White's imo
Night shot
Clarkey16
Re: My Jeep mod's
Unread post by Clarkey16 » November 16th, 2014, 4:23 pm
My Roo Systems 2x2.5 awning.
boof
Re: My Jeep mod's
Unread post by boof » November 17th, 2014, 1:46 pm
Nice setup
2014 FJ with a few mods
Clarkey16
Latest Mod :(
Unread post by Clarkey16 » December 5th, 2014, 9:01 pm
Rookie mistake on my behalf :(
This is what happens when you are to lazy to disconnect both sides of your sway bar :urgh:
Last weekend at Mt Airly
Clarkey16
185 watt cree led's
Unread post by Clarkey16 » December 24th, 2014, 7:03 pm
Did a group buy with a work mate for some 185watt Cree led lights direct from china.
Cost was $375 a pair delivered.
I like the look, finish's off the front nicely I think & love the distance :p
185 watt compared to 90watt below
1 down side, the wife won't let me use high beam when she's in the car as the signs reflecting back hurt her eyes. :waycool:
Toyholden
Re: My Jeep mod's
Unread post by Toyholden » December 27th, 2014, 1:20 pm
Looking good mate!
Those lights put out some lumens dont they!
Get the misses some new sunnies for night driving :D
Re: My Jeep mod's
Unread post by BigDutchy » December 27th, 2014, 2:47 pm
I like this a lot. Great built up. Great to read about something different.
As I hope to go back to 1 4WD in 2015 ( I have a Patrol and a Rodeo) I might look into this option too
I might have missed it but is this a V8 or a diesel?
Clarkey16
Re: My Jeep mod's
Unread post by Clarkey16 » December 27th, 2014, 6:50 pm
Diesel 3ltr 160Kw & 510Nm,If I wanted to spend $1k it can be chipped to 190Kw & 600Nm.
Running mud terrain tyres I am getting 13ltr per 100km around town & 10ltr on the hwy. With my second set of A/T's I can get high 8's on the hwy.
And 3.5 ton towing
An online buddy has just listed his on carsales, he has just upgraded to a new one.
http://www.carsales.com.au/private/deta ... =1&sdmvc=1
Clarkey16
Re: My latest mod
Unread post by Clarkey16 » February 1st, 2015, 6:29 pm
Thinking of ATX Texan's as replacements?
And a few poser pic's
Re: My Jeep mod's
Unread post by BigDutchy » February 1st, 2015, 8:52 pm
Great Photo's, great car, great location.
Where about are these photo's taken?
