80 Series Ute, engineering is next
patroler
Re: Another 80. chop done, tray started
Unread post by patroler » November 29th, 2014, 8:23 am
other side back together
wiring to the rear
patroler
Unread post by patroler » November 29th, 2014, 8:25 am
bit of inside back together
front housing stripped and out
they're concrete filled except the top one, jack stands weren't even close to long enough. It's stable.
patroler
Unread post by patroler » November 29th, 2014, 8:29 am
tray near ready to go back on
old v's new front brake pistons
old pistons
new ones
Not a very good picture, but i got adjustable castor plates welded in. Perfect castor for 0-4 inch lift whilst using the standard rubber bushes. 100% road legal.
Toyholden
Re: 80 Series chop done, adjustable castor installed
Unread post by Toyholden » November 29th, 2014, 10:46 am
Unreal ....
H8 seeing these chops cause it makes me wanna chop the Surf :urgh:
Can you explain a little more on how the adjustable castor plates work, please? as it may be an easy option for my SAS conversion on the Surf.
Coming along nicely dude!
dar_sbb
Unread post by dar_sbb » November 29th, 2014, 10:45 pm
Brilliant work mate
Goldylux
Unread post by Goldylux » December 11th, 2014, 12:58 pm
Maybe you should chop your shed and raise it? :lol:
Honestly though,awesome build. Very impressive.
patroler
Unread post by patroler » January 10th, 2016, 10:08 pm
Its been a while !!!
patroler
Unread post by patroler » January 10th, 2016, 10:14 pm
trying to get the truck guard to line up
fitting the sub tank back in
bit of advertising for a mate
getting it back together
bit of wiring starting in the extra cab
first drive, 400m down the road when moving house.
semi decent tyres on
patroler
80 Series Ute, Engineering next
Unread post by patroler » January 10th, 2016, 11:12 pm
Tappet cover gasket and plug seals
going back together
not sure what this one was, but the 1st aid kit means i cocked up somewhere.
i enjoy parking it next to the navara
1st time it was drivable in a while
Snorkel on
my mate keeping me company
patroler
Re: 80 Series Ute, engineering is next
Unread post by patroler » January 10th, 2016, 11:34 pm
dark under bonnet
lights on
perfect lighting for fixing night time stuff ups
patroler
Unread post by patroler » January 11th, 2016, 7:42 am
Speaker box for CB. The remote head one i have has the speaker inside the unit, so when i hid it under the dash i could barely hear it, no problems now, it is really loud.
210w light bar. 20 inch
invertor and a fuse box
patroler
Unread post by patroler » January 11th, 2016, 7:45 am
inside fuse box
old faithful mono amp
fuel filler till i come up with a better way. There will be a new tray at some stage, i have to work out what i want first.
patroler
Unread post by patroler » January 11th, 2016, 8:38 am
Cooler to go in soon.
re-located washer bottle to allow for the second battery
tray floor covering ready to do in the next few days
speaker pod out of a vr commy, they're the perfect size for the front doors, can get another couple of speakers in then.
ohh well that should be up to date again.
typhoeus
Unread post by typhoeus » January 14th, 2016, 8:36 pm
Your project is coming along nicely mate, Just have a quick question about your front brakes. . . Can you please tell me what size disc and thickness the front brakes are? Im looking to upgrade my Hilux discs from 20mm thick standard to 25 mm thick surf items, that's the easy part. . getting calipers to suit 25mm thick discs is harder. So if yours are 25 mm thick, I could possibly use those size callipers. Were they marked with SW13B cast into it somewhere and have 45mm pistons?
