TRAVIS - HJ45, 12HT, 5 Speed, 35", Pwr Steer, Rebuild
Corey 5
Re: TRAVIS - HJ45, 12HT, 5 Speed, 35", Pwr Steer, Rebuild
Unread post by Corey 5 » August 21st, 2013, 10:04 pm
Ok time for some more photos that are of the same day i moved TRAVIS into the shed :D
Bj40 - 1980, 33" BFG Mud Terrain, Disk Brakes, Modified Suspension
Hj45 - 1980, Currently being built with a 12HT, 5 Speed, Power Steering, Disk Brakes, Rear Air Locker, 35" Muddies, Engineered, Complete respray including chasis
http://www.4wdaction.com
Unread post by Peter Aawen » August 21st, 2013, 10:10 pm
Welded, nah - just tightened up all the left hand as tight as he could by hand, then went around the other side of the car and tightened all that up as tight as he could, but that hauled so much pressure on the LHS that it made it almost impossible to get off, UNLESS you undid all the RHS stuff first, then tried the LHS! :doh:
Doesn't it all look like so much fun ahead of you? Betcha never thought rust could be quite everywhere like that! But you'll get there, keep at it, and keep the pics coming! ;)
Corey 5
Unread post by Corey 5 » August 21st, 2013, 10:25 pm
Corey 5
Unread post by Corey 5 » August 21st, 2013, 10:33 pm
Then i un-did all of the bolts that hold the roof on. If you are doing this or plan too, make sure you do the ones out the front that go into the windscreen :D i would also advise that having someone to help out, it would take half the time! I unfortunately was this lucky but i made do :D
Corey 5
Unread post by Corey 5 » August 21st, 2013, 10:37 pm
Corey 5
Unread post by Corey 5 » August 21st, 2013, 10:40 pm
More photos to come later this week guys, comment your throughts!!!
The next bunch of photos comes with a surprise so keep watching!
Corey 5
Unread post by Corey 5 » August 24th, 2013, 9:15 pm
Continued...
Corey 5
Unread post by Corey 5 » August 24th, 2013, 9:29 pm
Missy
Unread post by Missy » August 24th, 2013, 9:36 pm
That amount of rust is manageable :D
At least Farmer Joe never met expanding foam... try seperating panels with 15 gallon of that stuff between the tub and body panels :lol:
Corey 5
Unread post by Corey 5 » August 24th, 2013, 10:11 pm
Corey 5
Unread post by Corey 5 » August 24th, 2013, 10:16 pm
Missy wrote:That amount of rust is manageable :D
Yeah its not as bad as iver seen some people try to resurrect.
that would not be fun!!!
Corey 5
Unread post by Corey 5 » August 24th, 2013, 10:27 pm
Corey 5
Unread post by Corey 5 » August 24th, 2013, 10:41 pm
Almost up to date!
Corey 5
Unread post by Corey 5 » August 24th, 2013, 10:56 pm
Ok thats the end of this days work, i then went on to try and hunt down a handbrake rear diff for the 5 speed conversion. I was going to bid on one but it ended up out of my price range but then one came up just near home so i grabbed it, turns out he also had some 35's which i tried on for size :D
Cost so far:
$6480 + handbrake diff = $150
Total $6630
Corey 5
Unread post by Corey 5 » August 24th, 2013, 10:59 pm
Peter Aawen wrote:Welded, nah - just tightened up all the left hand as tight as he could by hand, then went around the other side of the car and tightened all that up as tight as he could, but that hauled so much pressure on the LHS that it made it almost impossible to get off, UNLESS you undid all the RHS stuff first, then tried the LHS! :doh:
Cheers Peter!
Hahah that is a great theory, never thought of that one. i must have been :drink: enough
Yeah i love it and i will try to keep the photos coming for you mate!
