cant sleep so here's a few other bit's i'v been doing
the ECU i need to flip brackets to fit it & try work out the wiring on the plug
so brackets & relay are flipped & ECU is secured behind glove box door, yet to clearance/trim the back of door
the 3 plugs on the left jack into the ECU but the 4 on the right are body plugs that i need to decipher
this one i can delete as it's cruise control & i wont be needing that
This plug i need to wire the fat black one in the middle to hilux starter solenoid relay & the black red stripe & black orange stripe need to be switched by IGN2 via relay & yet to work out what the others do & which to delete
I believe this plug on the right gets connected to the black wire in the middle on the plug on right, hope so
then there's these 2 plugs i know there's igniters & something else important just cant remember ATM what some of the wires on here do but have it written down just need to also work out what i need & what i can delete
Cant believe the size of the hole & gromit for this tiny wiper motor loom & it's the right size for the 1UZ loom gromit, perfect, just need to relocate the wiper motor loom to the side
So i relocated it, just need a piece of split conduit to cover the loom but it's out of the way of the 1UZ loom now
So still cant connect loom till i lift out motor 1 last time to weld on the exhaust header flanges, maybe tomorrow will see how i go for time!
