106 Hilux, crossover, 3 link rear. Tough tourer
94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 8:51 pm
im finally setting up a buildup, even though my 4b is almost at the point where im happy with it, ive still got a few things i want to do to it..
the story goes i bought it from my uncle 3 years ago sitting in a paddock going to waist. he used and abused it for years until he moved on with a newer car.
it had a freshly rebuilt 2.8, like 10000ks fresh, with a fresh denco turbo kit running 14psi.(a bit high i think)
f n r 4;3 lsd's
and a cool comp bar
i owned a ln65 with a fair bit of work done to it so i started swapping all the good bits over
i swaped; the diff centres over, i had a trutrac in the rear of the 65, and i prefer the 4;5 ratio
alloy radiator
all the suspension, new 3"EFS
front tailshaft
i then regoed it, 2months later took it to the cape..
myself the missus and my 2 best mates set off as 21yr old mud monkeys to do the cape from brisbane in 14 days( work comitments) TRIP OF A LIFETIME!!!!
the worst thing happened to me that changed my life forever, i lost my best mate to a accident on the way home. it took the high away real fast.
the rebuilding of my ute is dedicated to him.. "
Last edited by 94 TURBO HILUX on May 19th, 2014, 10:01 pm, edited 6 times in total.
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 8:58 pm
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 9:02 pm
top photo was me "reversing" into gunshot, just for laughs, and to see how tall it was. th next is just before you get to gunshot and the third is Hann River Roadhouse, our first camp from cairns
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 9:05 pm
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 9:41 pm
What ive done to rebuild it so far;
new clutch with a modified presure plate
rear main seal and bearing
new genuine engine mounts
new gearbox mounts
new fan clutch
new aftermarket 8 fin fan from a 5L
new belts
aircon comp
new radiator and heater hoses
new high flow thermostat
rebuilt surf gearbox
new pitman arm, drop drag link, tie rods
all the bearings
all the uni joints
what i have fitted or done to it;
moved the diff forward and braced the spring mount
superior diff guard
ARB air locker in the front
detroit trutrac in the rear
one piece tailshaft 5mm tube
spacers in front tailshaft
inverted rear shock kit
surf air box to run duel batteries under bonnet
new redarc duel batery kit
optima red top battery
T/M intercooler, bonnet scoop
boost gauge
mechanical water temp gauge
SAAS bucket seats
Surf interior for the bling bits
led lights in side the cab
lightforce 170s
comp bar
uniden cop scanner UHF
fully sound proofed interior and inside doors
alloy tray
rear spotties
6 12v plugs around the car
300w and 1000w power inverters
custom high mount and shovel mount in tray
custom fridge slide
40L engel
hidden under tray toolbox
yep its a money pit..
puplux
Re: 94 TURBO HILUX
Unread post by puplux » May 29th, 2012, 10:00 pm
SORRy to hear about your mate , , good to see another lux out there pretty much sounds like my car ,
CAn We see a few more shots
get out there and get dirty!!!!!!!!!!!!!
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 10:05 pm
im just trying to work out why the iphone photos on my computer arnt uploading
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 10:18 pm
gunshot creek and just a posser shot before the new wheels
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 10:32 pm
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 10:34 pm
its not any heavier than a normal bar, i can pull it off and put it on myself. the top hoop is alloy. and the springs seem to have handled it..until i put a winch in.
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 10:39 pm
this is a comp tray i built but after it being on for a couple of months i realised it drew too much attention.. at the time i had ext shackles and the police were cracking down on anything so thats why i went the alloy tray.
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 10:58 pm
capesy
Re: 94 TURBO HILUX
Unread post by capesy » May 29th, 2012, 10:59 pm
nice hilux mate, sure does have some flex to it
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 11:07 pm
i painted my bullbar white, i never liked the red, it came with red when i bought it.
and the under tray toolbox i built for my mates patrol. mines the same as that one except the way i mounted it. coz my alloy tray has the main rails.
94 TURBO HILUX
Re: 94 TURBO HILUX
Unread post by 94 TURBO HILUX » May 29th, 2012, 11:17 pm
next up ive gota play with my rear leaf pack a little, just to make it work a little easier. ive thought about ifs rears but i dont want to run ext shackles, unless theres a way to have 2"lift with ifs rears and a standard shackle.
all this heavy work will have to wait coz im only 2 weeks out of collorbone surgery and im stuck in a sling, 4 more week till im out of the sling. then leafs get done then landcruiser for a .. :D
