What would make the trailer brake fuse keep blowing?
Travelpro
Unread post by Travelpro » August 2nd, 2018, 8:11 am
Any idea what would be causing my 15 amp trailer brakes blade fuse to keep blowing?
Re: What would make the trailer brake fuse keep blowing?
Unread post by Peter Aawen » August 2nd, 2018, 11:00 am
Does it blow the fuse as soon as you connect the trailer plug, or does it wait until you press the brake pedal or turn the lights on??
Travelpro
Unread post by Travelpro » August 3rd, 2018, 7:23 am
I’m not sure Peter, but I think it happens when I press the brake pedal.
Unread post by Peter Aawen » August 3rd, 2018, 10:09 am
How good are you with operating a multimeter? If it blows when you press the brake pedal, it's most likely going to be a short or wiring error in that particular circuit. If you haven't used this trailer on your vehicle without this problem before, then it might be worthwhile to check your trailer plug wiring first, just to make sure the wiring matches & isn't the cause of the problem. But if it's not that, then sorry, it's probably time to pull out the multimeter & start checking every wire & circuit, starting with the brakes! :o
Travelpro
Unread post by Travelpro » August 3rd, 2018, 1:49 pm
Thanks Peter, I'll check the wiring and get out the multimeter>
