Non winch bar to winch bar ???
gmhgq
Unread post by gmhgq » December 14th, 2016, 5:39 pm
Hi all,
Has anyone converted a ARB non winch bar to fit a winch.
Can you buy mounts off the shelf.
Would it be legal.
Can't really afford the expense of a new bar.
Re: Non winch bar to winch bar ???
Unread post by Peter Aawen » December 14th, 2016, 6:11 pm
Short answer - it's not quite that easy!!
Longer answer - it has been asked & done before, but the critical bits are the bar mounts & the front face of the centre panel of the bar between the mounts - they need to be strong enough to support all the winching loads AND any shock loads!! Tell you what, have a bit if a read in this lot! ;)
http://www.4wdaction.com.au/forum/searc ... mit=Search
(You might hafta copy the complete search string into your browser address bar. :o )
Return to “Body and Barwork”
