r/h rear axel seal leaking and im on fraser lsland
zac9991
Unread post by zac9991 » March 9th, 2016, 4:26 pm
Just got of the barge at Fraser set up camp noticed rear seal leak and smell of diff oil don't leave till Saturday what are the risks in driving around until I get to gympie on Sunday
Zac
typhoeus
Re: r/h rear axel seal leaking and im on fraser lsland
Unread post by typhoeus » March 9th, 2016, 8:54 pm
Firstly, check that the diff breather isn't blocked. If its clear, Just keep the diff topped up, & check regularly. When U get back to civilisation, get the seal replaced then. . and probably the rear brake shoes/pads as well, as they might be impregnated with oil by then.
zac9991
Unread post by zac9991 » March 9th, 2016, 9:36 pm
Oil level OK what I found was that 4 off the hub nuts where loose how it happened don't know you could turn by hand so hopping that was the cause see what happens tomorrow when we head up orchard beach
zac9991
Unread post by zac9991 » March 10th, 2016, 9:40 pm
Removed breather hose from top of diff could hear the pressure release gave it a good clean with air compressor re- tighten hub nuts so how it goes till I get to gympie on Monday
Return to “Engine and Driveline”
