new exhaust - how do I take the heat shield off?
wim
Unread post by wim » February 28th, 2016, 7:31 pm
at the turbo end how do I take off the heat shield to get to the bolts and were are the sensor plugs on the pipe :crazy: Wim
navara07
Re: new exhaust - how do I take the heat shield off?
Unread post by navara07 » March 6th, 2016, 2:43 pm
4 or 5 8-9mm small bolts the hardest part is to get the dump pipe out only comes out a certain way drive you nuts getting it out. You need to remove heat shield to allow more room to twist and turn dump pipe. Plug in sensors I had none this is on 2015 Rg Colorado.
