Nemesis
Unread post by Nemesis » September 12th, 2014, 4:38 pm
Originally started as a research topic years ago in the older utes sections, the tyre topics are so popular it's time to start an new info archive in each sub section, not just for the older ute people!
Sangelides
Unread post by Sangelides » September 15th, 2014, 9:51 am
I need to know if anyone put Mickey Thompson p3 285/75 R16 on the bt-50, whether it was a good fit? Or what u did to get them to fit? & how do find the new version to the old one?
macmanluke
Unread post by macmanluke » September 15th, 2014, 1:05 pm
285/70R17 on a 17x9" +18 rim
Stock height: Slight scrub at full lock/full compression. Nothing major.
2" Lift: Perfect, like it was made for it.
BigArseBT50
Unread post by BigArseBT50 » September 15th, 2014, 10:05 pm
I've got Mickey Thompson P3's on my Bt50, 285.70.17 (33's). I have a 2" tough dog lift. All fits perfect. Before the P3's I had MTZs in the same size. I got those before the 2" lift and they fit no problems, no scrubbing
Always itchin' for the next big trip .......
Dazandyue
Unread post by Dazandyue » December 23rd, 2014, 7:48 pm
i would like to fit 285x70R17 but am wondering what people do with the spare tyre. i cannot see how it would fit underneath unless i replace the towbar with an aftermarket rear bar with a swing away wheel carrier. feedback on what others have done wold be great.
ab67
Unread post by ab67 » December 25th, 2014, 11:31 am
305/70/16 muddies on 16x8 pos45 rims with 2inch lift
33s will fit on bt50 or px with std suspension
ab67
Unread post by ab67 » December 25th, 2014, 11:36 am
Dazandyue
Need a ford towbar or a tjm or arb rear bar etc, tjm cost me $1100
32s in pict now 33s and ok
Kaymar is the best but costs abit
Dazandyue
advice on what size tyres to fit
Unread post by Dazandyue » January 4th, 2015, 12:53 pm
hi guys, I'm just after some thoughts from others about what larger size tyres to fit to my 2013 BT50. I was thinking of 285x70R17 mainly because the extra diff clearance it provides but below is a few concerns I have and any thoughts from others would be appreciated.
- I run the mazda boss adventure alloy rims which are 8" wide with a different offset to the standard and even my standard 265x65R17 tyres stick out about 15mm from the guards so 285'swould stick out even further. I would imagine it would be pretty noticeable from a police vehicle travelling behind me but not sure if they would even care about this, the tyre diameter is bigger than the 50mm allowed limit in vic anyway but I highly doubt anyone would pic up on that.
-because I have the different allow rims 8" wide, the spare I would imagine would be a 7" steel rim, so I think I would need another spare rim to fit a 285 tyre too.
-The spare wont fit underneath the vehicle as its too large so its a good excuse to grab a rear bar, thinking the TJM bar as it appears like it has the best rear angle clearance. Kaymar would be great but they are a complete rip off and the MCC rear bar with swing away's doesn't have any side protection but it would be great to have the version with the twin jerry cans on the rear.
-I am concerned on how noticeable the larger tyres will make on the power. Have others fitted 285's and noticed a massive loss in power and regretted it?
The simplest option is to fit 265x70R17 tyres but they aren't really that much bigger than standard so in my opinion it wont really make much of an advantage offroad. I'm just not sure which way to go, its a pity they don't make good muddies in 275x70R17 tyres as that would be a great compromise. any suggestions would be greatly appreciated.
Mal5618
Unread post by Mal5618 » January 15th, 2015, 4:42 pm
Hey dudes.
I just got a set of 285/70R17 for my XTR MY2014. No lift YET and they fill the arch well. No rubbing anywhere.
Before.
After.
bsben
Tyre size
Unread post by bsben » January 24th, 2015, 6:23 pm
Just wondering if anyone is running 35's, on the new ranger
- what suspension are you running?
- is there enough power?
- what offset rims are you running?
kiran92
Unread post by kiran92 » February 2nd, 2015, 12:29 pm
My '12 GT is running 285/70/17's.
There's a small amount of rubbing on the inside at full lock, it's running up agaisnt some sodt plastic.
No lift.
Not sure how it was prior as I bought it with them on.
@ Mal: I'm guessin the 2014 must be a little different in the wheel arches as mine do rub.
Mal5618
Unread post by Mal5618 » February 3rd, 2015, 1:26 am
kiran, ill check that out tomorrow and get back to ya. Ill do a full lock and have a look-see.
Note: My mate has the 2012 and it seams identical except for our seats.
kiran92
Unread post by kiran92 » February 3rd, 2015, 10:42 am
Cool, it'll be interesting to see.
Hopefully I'll be able to get my wheel alignment and balance done this week, may resolve it.
the rubbing isn't doing any harm so its more an annoyance factor
Mal5618
Unread post by Mal5618 » February 7th, 2015, 5:16 pm
Sorry for the delay... computer trouble.
With my 285/70R17 at full lock both ways I've got about 30 to 35mm clearance. So no problem there and that's no lift either.
kiran92
Unread post by kiran92 » February 11th, 2015, 10:43 am
Hmm, well I still haven't got my wheel alignment work done, so I'll wait out.
Whats your offset?
